    Outliner selection not in Order
    11 Posts 5 Posters 2.1k Views 5 Watching
      Perhaps sel.to_a.sort might work ?
      BUT, to sort the definition names [properly], I suggest you 'start at the other end' !
      names = sel.grep(Sketchup::ComponentInstance).collect{|i| i.definition.name }.sort
      that's a sorted list of selected instances' definition-names...
        driven
        mod = Sketchup.active_model # Open model
        ent = mod.entities # All entities in model
        sel = mod.selection # Current selection
        names = []
        sel.each { |e| names.push(e.definition.name)}
        p names.sort
        • K
          ktkoh
          That is still not the result I am looking for. I need the sel entity list (all entities are comp instances) but the entities should be in order by their def name. I can't see a way to get back to the entities from the name list. Perhaps a better way would be to sort the pages after completion. I don't know if that is possible
          thanks
          Keith
            slbaumgartner
            How about this: you need to tell sort that you want to compare the names to determine order.
            sorted = sel.grep(Sketchup;;ComponentInstance).sort {|a,b| a.name <=> b.name}
            If you want to use the definition names, just insert .definition between a,b and .name
              Once you have a list of ordered definitions 'names' you can then access them using something like this:
              defns=[]; names.each{|name| defns << model.definitions[name] }
              then you have ' defns' as an ordered list of definitions, arranged by their previously sorted names...
              πŸ˜•
              This is not, thus far, rocket-science...
              • K
                ktkoh
                TIG It may not be rocket science but so far none of the ideas has helped me get a list of instances sorted by the component name. Now if I temp add a instance name = definition name would that make the list easier sortable?? I came to programing late in life so it is not like a second language to me and I have appreciated the forum help. I hope I have not asked too often. I do look for examples and try several ideas before I ask here.
                Keith
                  @Keith
                  Let's start back at the beginning...
                  I now think I see what you want to do...
                  It wasn't obvious thus far...
                  Please don't be put off asking - just ask as clearly as you can.
                  You have a selected 'sub-set' of the current context's entities.
                  You want to list any instances in that selection, arranged in the order of their definition-names.
                  model=Sketchup.active_model
                  instances=model.selection.grep(Sketchup;;ComponentInstance)
                  ### an array of instances, unsorted.
                  ### Make a list of definition names
                  names=[]
                  instances.each{|i|
                    names << i.definition.name unless names.include?(i.definition.name)
                  names.sort!
                  ### an array of definition-names sorted alphabetically.
                  sorted_instances=[]
                  names.each{|name|
                    instances.dup.each{|i|
                      if i.definition.name==name
                        sorted_instances << i
                        instances.delete(i)
                  ### we now have an array of instances sorted by their definition-names alphabetically.
                  To get all instances in the active context [no selection considered], then substitute:
                  instances=model.active_entities.grep(Sketchup::ComponentInstance)
                  • Dan RathbunD
                    Dan Rathbun
                    I need to point out again that Steve gave the correct answer
                    So following the last sentence (in Steve's post,) you insert the .definition into the block twice, thus:
                      a.definition.name <=> b.definition.name
                    The block uses <=>, which is the Ruby comparison method.
                    This means that the expressions on each side of the <=> must be comparable, which means that at the least, their class must define a <=> method (and might also mixin in the Comparable module.)
                    I'm not here much anymore.
                    • K
                      ktkoh
                      Thanks Dan when I added definition where you suggested that code worked very well. I had been adding it in the wrong place after the instance. And I appreciated the English description of what the code was saying.
                      THANKS TO ALL THE FORUM CONTRIBUTORS THAT HAVE HELPED ME!! I seem to have the ability to imagine programs that would help speed up manual operations but using the API samples to write code is a crap shoot at best. Would have not bothered without the great help available here.
                      sorted = []
                      sorted = sel.grep(Sketchup::ComponentInstance).sort {|a,b| a.definition.name <=> b.definition.name}
                      sorted.each { |e| UI.messagebox(e.definition.name)}[/code]
                      • Dan RathbunD
                        Dan Rathbun
                        You do not need sorted = [], as grep makes a new array, then sort makes another new array.
                        Save yourself some grief. Use puts or pp output to the console, rather than UI.messagebox, for testing. ( UI.messagebox can fail silently if the C WinAPI functions do not like the string passed to them.)
