    Problem Importing 3D DWG
    6 Posts 2 Posters 1.2k Views 2 Watching
      dirumos
      Hi to all, and thanks for your futures answer and time.
      I'm trying to import a 3D DWG to Sketchup. I get this message.
      https://www.dropbox.com/s/iub2s1y0zmf5kxo/1.png?dl=0
      But then, when the model is displayed, it isn´t like the CAD view, see images bellow.
      CAD Imported view in Sketchup
      https://www.dropbox.com/s/zl37b5dsogg9bmn/2.png?dl=0
      Model View in Civil3D
      https://www.dropbox.com/s/g1d7h527ny7idh0/3.png?dl=0
      I've attached the DWG file.
      https://www.dropbox.com/s/apfpvew2y7wfutl/Area%20Montaje%20Julio%202015.dwg?dl=0
      I've reinstalled Sketchup, purge the DWG file before importing, I don't know what to do.
      Please help me.
        What Units was the original DWG in ?
        What Units did you set in the Import Options ??
          dirumos
          Hi TIG, thanks.
          I'm using meters in both Civil and Sketchup.
            The SKP's model-units is not relevant.
            What Units did you choose in the "Options" settings under the DWG Importer's dialog [separate button on the dialog].
            If it's left as the default 'inches' then 1m will be assumed to be 1" on import.
            If the DWG's dimensions are small, then you might fall foul of SketchUp's 1/1000" tolerance limit ?
            And some imported geometry might get corrupted...
            E.G. 0.001m is 1mm, but 1/25.4 smaller when assumed to be in inches !
              dirumos
              Hi TIG,
              I'm importing using meters.
              https://www.dropbox.com/s/9cqcqiexema432d/6.png?dl=0
                I tried to import your DWG using the Options > Units of Meters...
                It imports.
                There are issues. because the 9 groups that are created have their origins miles away from their geometry, so the appearance is weird and any orbiting etc is awful - jittery.
                You have two choices.
                Either make each group in turn into a component using the context-menu, then immediately change its axes to a sensible corner on its geometry [context-menu again]. After doing all 9 it'll be fine.
                Or select the 9 groups and use 'Explode' [context-menu again] so their geometry is merged into one context, and their badly located origins are forgotten...
                Another possibility would be to remake the forms entirely in SketchUp - its some simple 3d geometry for one [pushpull/offset/move] and an array-copy to make the 9...
