    Can you apply double click function to MOVE tool?
    5 Posts 3 Posters 505 Views 3 Watching
      sketchuh
      Hi you all, I need to move several objects in X direction. lets say I move object 1 in direction X, 1.543 meters,
      then I move object 2 in direction X, 1.543 meters. BUT I can only type in that 1.543. it gets very cumbersome.
      if using push pool tool, you can just double click the face, then all the faces will push pool to that same distance.
      I wonder if there is a plugin to let me input a value then select the objects then all the objects will be moved with the same value.
      you may ask why not select all the objects then move them all at the same time. the problem is I need to move objects in different groups. I don't think you can select objects within different groups at the same time.
      hope my question is clear. let me know what you think. thanks in advance.
      • ely862meE Offline
        ely862me
        When you move an object and you insert the value in the vcb and hit enter, that value is recorded in the background. The next time when you manually move an object on a given direction or axis it will snap when it reaches that length. That's valid only with the last inserted vcb Move tool value though.
        Elisei (sketchupper)
        Come and See EliseiDesign
          sketchuh
          wow never knew...lol...glad i asked...thanks!!
          • fredo6F Offline
            fredo6
            For info, FredoTools::MoveAlong support the double click as Redo (both direction and offset).
            Fredo
              sketchuh
              awesome fredo! thanks!
