Updating SU
Hi I'm always dropping in and out of using SU, I currently have the 2015 pro version when I click update it wants me to download the program again is that correct?
Also I have the SU pro for Mac am I able to swap the licence to Windows? I don't mean swap between the two I mean completely swap, or would I have to pay again.
Thanks Andy
There has been an update to SketchUp v2015 so you should install the newest version, which fixes a few issues [note that this update is at no cost].
With SketchUp v2015 Pro the same license-code will now work on both PC or MAC.
So in theory if you also install SketchUp v2015 Pro on a MAC you can activate it with the same license code you already have.
If the two computers are on the same network, then only probably only one version SketchUp will get licensed at a a time - the license-checker spotting if that license is already used on the network and then preventing a duplicated use...
Register LoginAdvertisement
