    Substance and Sketchup Workflow
    107 Posts 9 Posters 27.4k Views 9 Watching
    • JQLJ Offline
      JQL
      True!
      www.casca.pt
      Visit us on facebook!
      • KrisidiousK Offline
        Krisidious
        I've found that Substance Designer is retarded when it comes to movement... I don't know why these companies cannot let me determine the uses of my mouse and navigation.
        By: Kristoff Rand
          roland joseph
          I don't see where this doesn't go the full distance
          I'll be sure to keep an eye open for anything that comes out of this conversation. πŸ˜’
            Krisidious
            Yes, I was overly excited and mistaken. I've been experimenting all weekend, as well as breaking the importer. and... Yes, I think I got lucky on that stone and concrete. They happened to wrap the corners very nicely. My other tests have not had that result. UV's are indeed a wall that must be mounted and climbed before you can have any good result, not only that. but normals don't even seem to read correctly in SD. While this works well on flat surfaces and simple shapes, 90 degree corners and rather simple topography does not do well in most cases. Grass and Dirt hides the imperfections in SU's normal creation.
            Now, I'm going to see what Thea's procedural mats and see what can be done with it.
            And I'll be damned if I didn't install Blender...
            By: Kristoff Rand
            • JQLJ Offline
              JQL
              That's the only thing I did so far.
              I managed to import a perfect model into blender using blend up (wich I highly recommend...);
              I managed to create an Unwrapped UV layout very easily;
              I managed to import it back to sketchup as DAE and the geometry was perfect. The thing is I can't seem to bring the UV unwrapped Material back with the model...
              www.casca.pt
              • JQLJ Offline
                JQL
                I've managed after all, it was a simple matter of ticking a box in the Export Collada options: "Include UV textures"
                www.casca.pt
                  Krisidious
                  Awesome. that's why I installed Blender, not for this but for my Simulator Mod. Some guy over in that forum made a blender plugin to import and export the models, so I was testing it to replace Max... as I hate Max. next on my list was testing Blender's UV mapping & unwrapping.
                  Though, in the mean while I found something else... and it's kinda awesome. 3D Coat.
                  It also does some fantastic "re-topology"...
                  By: Kristoff Rand
                    roland joseph
                    These guys are very good...although I have not started, the curriculum looks really thorough and the approach seems to be for dummies like me. πŸ˜• !
                    Looks like a great way to get to know the entire "Substance" science and application.
                    • JQLJ Offline
                      JQL
                      Roland I've been following Substance Videos and although my own substances are still bitmap based, I really can tell this is big!
                      Nothing you can't do with it.
                      I'm taking advantage of Thea's Substance Converter so the simplest workflow for me is as follows:
                      • Sketchup Model;
                      • Export to Blender using Blendup (free for up to 1000 faces wich is not much so better buy it);
                      • UV Unwrapping within Blender with Smart UV Project (wich is automatic, fast and easily tweakable);
                      • Export as Collada;
                      • Import collada into sketchup and run Cleanup3 to merge faces keeping UV;
                      • Import into Substance Designer and work your texturing;
                      • Publish your substance as high as 16k textures (If you have enough GPU ram, I have a Titan X)
                      • Convert Substance to Thea material using Thea converter;
                      • Apply material in Collada model using Thrupaint to keep UV modes.
                      • Render!
                      www.casca.pt
                        Krisidious
                        • Sketchup Model;
                        • Render!
                        πŸ‘ πŸ‘ πŸ‘ πŸ‘ πŸ‘ πŸ‘ πŸ‘ πŸ‘ πŸ‘
                        By: Kristoff Rand
                          roland joseph
                          The link leads to a new set of videos available as of yesterday so you haven't followed theses ones.
                          • JQLJ Offline
                            JQL
                            I can tell you Kris, I can predict this becoming big at our office.
                            Materiallity is a big deal in architecture, there's no hatching or physical model that can replicate it!
                            I'm thinking of conceptual creative work based on procedurally generated textures with sketchup basic shapes and, in the future, maybe even blender...
                            www.casca.pt
                            • jason_marantoJ Offline
                              jason_maranto
                              I am glad you found a workflow that will allow you to incorporate Substances -- they are worth it IMO.
                              • JQLJ Offline
                                JQL
                                Thanks Jason,
                                Some procedural only work well at 4k, as they have to be upscaled for 8k or 16k. That is the only limitation I'm aware for now.
                                www.casca.pt
                                  roland joseph
                                  Gee, I never thought I'd see an SU/Substance workflow but you guys are breaking ground.... πŸ˜•
                                    Krisidious
                                    Well, we know we're not breaking ground, we may be able to use some substance outputs, but we're under no illusions that we're using true substances or that we will be able to. But, like with most things in Sketchup, it may not be top end, but it's good enough. I don't need live rendered substances, I just need good looking textures for on the fly renders. If I can take it out and take it to SD and get a better look and it doesn't take too long? I'll take it. But, I'm not selling renders... Pro Rendering guys may not think this passes the sniff test. And they're probably right. I'd call it a shortcut.
                                    By: Kristoff Rand
                                    • K Offline
                                      kaas
                                      Anyone using Substance ever tried making overlapping wood planks? Something like this? http://www.textures.com/download/woodplanksoverlapping0030/46418
                                      Can it be done or should I better model it in 3d instead. I would be using the output in Unreal Engine (normal map / ao map / heigth map / roughness map).
                                        The guys over at gametextures.com have a wood siding material...
                                        https://www.gametextures.com/wp-content/uploads/2016/02/screenshot0011-512x512.png
                                        • JQLJ Offline
                                          JQL
                                          That is rather basic to make with substance designer, Specially if you don't need knots.
                                          If you need something as grungy as what Rich showed, it will be harder to make it realistic.
                                          www.casca.pt
                                          • K Offline
                                            kaas
                                            Thanks for the suggestions. Learning Substance is on my to-do list but I'm reluctant to start learning another complex program because I'm short on time. Went back to AwesomeBump and did some manual tweaking of maps in Gimp.
                                            • 6
                                            • 5 / 6
