    Substance and Sketchup Workflow
    107 Posts 9 Posters 26.2k Views 9 Watching
    • JQLJ Offline
      JQL
      @jql said:
      @krisidious said:
      And I'll be damned if I didn't install Blender...
      That's the only thing I did so far.
      I managed to import a perfect model into blender using blend up (wich I highly recommend...);
      I managed to create an Unwrapped UV layout very easily;
      I managed to import it back to sketchup as DAE and the geometry was perfect. The thing is I can't seem to bring the UV unwrapped Material back with the model...
      I've managed after all, it was a simple matter of ticking a box in the Export Collada options: "Include UV textures"
      www.casca.pt
      Visit us on facebook!
      • KrisidiousK Offline
        Krisidious
        Awesome. that's why I installed Blender, not for this but for my Simulator Mod. Some guy over in that forum made a blender plugin to import and export the models, so I was testing it to replace Max... as I hate Max. next on my list was testing Blender's UV mapping & unwrapping.
        Though, in the mean while I found something else... and it's kinda awesome. 3D Coat.
        It also does some fantastic "re-topology"...
        By: Kristoff Rand
          roland joseph
          These guys are very good...although I have not started, the curriculum looks really thorough and the approach seems to be for dummies like me. πŸ˜• !
          Looks like a great way to get to know the entire "Substance" science and application.
          • JQLJ Offline
            JQL
            Roland I've been following Substance Videos and although my own substances are still bitmap based, I really can tell this is big!
            Nothing you can't do with it.
            I'm taking advantage of Thea's Substance Converter so the simplest workflow for me is as follows:
            • Sketchup Model;
            • Export to Blender using Blendup (free for up to 1000 faces wich is not much so better buy it);
            • UV Unwrapping within Blender with Smart UV Project (wich is automatic, fast and easily tweakable);
            • Export as Collada;
            • Import collada into sketchup and run Cleanup3 to merge faces keeping UV;
            • Import into Substance Designer and work your texturing;
            • Publish your substance as high as 16k textures (If you have enough GPU ram, I have a Titan X)
            • Convert Substance to Thea material using Thea converter;
            • Apply material in Collada model using Thrupaint to keep UV modes.
            • Render!
            www.casca.pt
              Krisidious
              • Sketchup Model;
              • Render!
              πŸ‘ πŸ‘ πŸ‘ πŸ‘ πŸ‘ πŸ‘ πŸ‘ πŸ‘ πŸ‘
              By: Kristoff Rand
                roland joseph
                The link leads to a new set of videos available as of yesterday so you haven't followed theses ones.
                • JQLJ Offline
                  JQL
                  I can tell you Kris, I can predict this becoming big at our office.
                  Materiallity is a big deal in architecture, there's no hatching or physical model that can replicate it!
                  I'm thinking of conceptual creative work based on procedurally generated textures with sketchup basic shapes and, in the future, maybe even blender...
                  www.casca.pt
                  • jason_marantoJ Offline
                    jason_maranto
                    I am glad you found a workflow that will allow you to incorporate Substances -- they are worth it IMO.
                    • JQLJ Offline
                      JQL
                      Thanks Jason,
                      Some procedural only work well at 4k, as they have to be upscaled for 8k or 16k. That is the only limitation I'm aware for now.
                      www.casca.pt
                        roland joseph
                        Gee, I never thought I'd see an SU/Substance workflow but you guys are breaking ground.... πŸ˜•
                          Krisidious
                          Well, we know we're not breaking ground, we may be able to use some substance outputs, but we're under no illusions that we're using true substances or that we will be able to. But, like with most things in Sketchup, it may not be top end, but it's good enough. I don't need live rendered substances, I just need good looking textures for on the fly renders. If I can take it out and take it to SD and get a better look and it doesn't take too long? I'll take it. But, I'm not selling renders... Pro Rendering guys may not think this passes the sniff test. And they're probably right. I'd call it a shortcut.
                          By: Kristoff Rand
                            kaas
                            Anyone using Substance ever tried making overlapping wood planks? Something like this? http://www.textures.com/download/woodplanksoverlapping0030/46418
                            Can it be done or should I better model it in 3d instead. I would be using the output in Unreal Engine (normal map / ao map / heigth map / roughness map).
                              The guys over at gametextures.com have a wood siding material...
                              https://www.gametextures.com/wp-content/uploads/2016/02/screenshot0011-512x512.png
                              • JQLJ Offline
                                JQL
                                That is rather basic to make with substance designer, Specially if you don't need knots.
                                If you need something as grungy as what Rich showed, it will be harder to make it realistic.
                                www.casca.pt
                                  kaas
                                  Thanks for the suggestions. Learning Substance is on my to-do list but I'm reluctant to start learning another complex program because I'm short on time. Went back to AwesomeBump and did some manual tweaking of maps in Gimp.
                                    applemango85
                                    Does anyone here use substance designer or b2m to create a material then bring it over to sketchup to render with the vray /indigo plugin?
                                    (Still figuring out if vray or indigo is best for me)
                                    I'm figuring out how substance could help me in my workflow so any experience from other members would be great to read about
                                    • JQLJ Offline
                                      JQL
                                      Substance designer creates textures and these textures can be used in any render engine if they are exported as bitmaps.
                                      I don't know about vray or indigo, but Thea has a Substance Converter where you input a substance .sbsar file, edit all available parameters of the file and create a Thea material with a click of a button.
                                      I use Designer for all material creation.
                                      www.casca.pt
                                      • jujuJ Offline
                                        juju
                                        Exporting / saving the various kinds of files for a texture created in Designer, you can compose this in Indigo AFAIK. So, no, not a converter available but still usable in Indigo with a little more effort.
                                          it is easy set designer to convert maps. but there's no correct roughness/metallic to spec
                                          that needs some extra work to get right. the thea converter matlab is your friend in this instance.
                                          • JQLJ Offline
                                            JQL
                                            But you can use the Spec workflow if needed, instead of the Roughness/Metallic.
                                            www.casca.pt
                                            • 5 / 6
