    "Save changes to Untitled?"
    19 Posts 7 Posters 3.6k Views 7 Watching
    • D
      djh
      Why does Sketchup ask me every time when I open a file "Save changes to Untitled?"? I didn't make any changes to Untitled and am not interested in Untitled. All I want to do is open a file.
      • TIGT
        When you open a new SketchUp model from a Template and close SketchUp you should not be prompted to save.
        However, there are some Plugins which make changes to a starting SKP file, even if unused - e.g. saving some special attribute or another...
        In that case, even though you have not done it yourself, the model has be changed so you will be prompted to save it.
        Try disabling some Plugins to see if the prompt stops...
        If you find the offending Plugin let us know, and tell its author...
        Normally a Plugin only needs to affect the model if it's launch, but some make changes when they load...
        • pbacotP
          Twilight render does this. They plan to fix that.
          • D
            driven
            if you open a new model and have a look in 'Materials in Model', 'Components in Model', 'Layers' and 'Outliner', you may find the culprits input...
            john
            • D
              djh
              Thank you for your response, pbacot. Can't figure our how to uninstall Twilight. Searched my whole computer, but it's not to be found. Yet it is located in Extensions/Twilight V2.
              Thank you for your response, TIG. "Try disabling some Plugins to see if the prompt stops...""
              Also, I uninstalled all of my plugins, but still get the dreaded "Save changes to Untitled?"
              Thank you for your response, driven. "if you open a new model and have a look in 'Materials in Model', 'Components in Model', 'Layers' and 'Outliner', you may find the culprits input..."
              Can't find 'Materials in Model, 'Components in Model' in a new model. 'Layers' and 'Outliner' are as they are supposed to be, I suppose.
              • TIGT
                If you use the SketchUcation Plugins Manager you can make a Set of the usual ones [so its easy to 'revert' later on...], then disable all of the them.
                You need to restart Sketchup for the Plugins to 'unload'.
                If you have no Plugins loading [except for the default su_ ones like dynamic_components] then the change must come from within the Template itself.
                Does your Template contain anything at all - like a DC ?
                • D
                  driven
                  next time it happens, choose save and post the skp and we can have a treasure hunt...
                  john
                  • P
                    Philw
                    Here you go see the attached,
                    This happens every time I open SketchUp and then go to open a file. don't know when it started but it been going on for awhile now.
                    Blank file from startup
                    • TIGT
                      Please read the earlier responses...
                      It seems you have ay least one Plugin Loading which makes changes to the new [as yet unsaved] model, so you are prompted to save it.
                      These changes might include adding various observers. adding model.attributes etc...
                      Most Plugins only make these changes when they are activated, however, some do so when they initially load - causing this message.
                      By disabling Plugins so that when you restart they do not auto-load you can find the culprit[s]...
                      For example, Twilight is a known suspect...
                      Tell us here AND let the Plugins' authors know by PM...
                      • TIGT
                        As Driven points out your model has these attribute dictionaries attached.
                        "GeoReference" "temp" "Something...Check the previous project to see the value we used" "GSU_ContributorsInfo"
                        The oddly named "Something...Check the previous project to see the value we used" dictionary contains tons of Vraykeys/values.
                        The other ones are commonly found in Templates, and offer no real issues.
                        So the question is... does Vrayadd these as every new model opens, or are they already in the Template ?
                        I suspect the former...
                        Disable Vrayand see what happens with a new model opened and closed with no changes made - still prompted to save ?
                        You are likely to want Vray only occasionally, so it seems odd to have it load every time SketchUp starts anyway - use the SketchUcation 'Plugins Manager' to Disable it and Temporarily Enable it during a session where you do need it [i.e. select it from the Disabled list + Orange button]
                        To list your 'empty' model's dictionaries paste this into the Ruby Console + <enter>
                        Sketchup.active_model.attribute_dictionaries.each{|d| puts"NAME = #{d.name}"; puts; d.each_pair{|k,v|puts"#{k} = #{v}"}; puts }
                        You can delete the unwanted dictionary by name, thus:
                        Sketchup.active_model.attribute_dictionaries.delete("Something...Check the previous project to see the value we used")
                        • P
                          Philw
                          When I get home I will create a new template and see if that fixes the issues. I’ve only had V Ray for a few months. I have one other issue that I suspect is related to V Ray or this template issue.
                          When I import a file I get these unfilled triangles at the axis point, do you think this is related to the template file also or is this some other issue?
                          • P
                            Philw
                            Sorry have not replied earlier , been busy with other issues.
                            But I did uncheck V Ray and tried it out and Sketchup quit asking me to save the untitled page and it loaded faster to boot. I then added the scrip below to the Ruby Console and got a long list of code. After adding the 2nd scrip it retuned with "#Sketchup::AttributeDictionaries:0x0000000b579d28", don't know what that means or what I should do if anything.
                            I also save a new template without V Ray,
                            But when I load it to work with it .(The only way I know how to turn it on is to go to Windows > preferences> extensions and turn it on from there)and then close sketchup and later reopen sketchup it load up with VRay,and asked the same save blank question, how is this possible?
                            Is this a V Ray problem (somehow I've loaded this program wrong?} or is there a way to have it load and behave like all other plug ins that don't load things I don't need on startup?
                            • greenskpG
                              greenskp
                              @tig said:
                              So the question is... does Vrayadd these as every new model opens?
                              @philw said:
                              Is this a V Ray problem?
                              YES and YES
                              Every time you open SketchUp, V-ray works anonimously on attribute from the Untitled model. In this case if V-ray is enabled, SketchUp always will ask for save the changes.
                              I disabled vray, installed the plugin Attribute Inspector, removed the attribute attached in my template and saved. Now the atribute from model is empty.
                              While Vray is disabled.....No more question on Untitled models. 😄
                              Attribute Inspector
                              • P
                                Philw
                                Thanks for your reply,
                                I will download it and try it out when I get home over the weekend.
                                What happens when I enable VRay, will the same thing happen? Do I need to disable VRay before I close the program every time?
                                • TIGT
                                  If you normally have Vray disabled then [provided no other Plugins are making changes to the SKP !] you won't be prompted to save an 'Untitled' [new] SKP when you exit it.
                                  BUT if you enable Vray during a session [with a new or reopened model], then Vray will have made changes to the SKP and you will be prompted to save it as you exit...
                                  It's just part of the price of using Vray !
                                  • D
                                    driven
                                    @TIG,
                                    I avoid it like the plague, but could an app observer turn it off on quit?
                                    Sketchup.extensions.each { |extension| n = extension.name; extension.uncheck if n =~ /Vray/}
                                    john
                                    • K
                                      kaas
                                      Save changes to untitled -> I had the same problem while I still used LightUp. At starting of SketchUp it added several components (light icons etc) and materials. To prevent this, LightUp was disabled in the preferences all the time and I would only enable it if needed. Annoying and I never understood why he wouldn't fix it.
                                      • P
                                        Philw
                                        Yes it is annoying but it’s something I’ll have the live with. At least I know what the problem is and that it’s not something I have done.
                                        Hopefully they will fix this sometime in future releases.
                                        Thanks All
                                        • D
                                          driven
                                          your 'empty' model has a load of vray attributes attached to it...
                                           "/SettingsImageFilter",
                                           "<Assets>\n <Asset renderer=\"vray\" url=\"/SettingsImageFilter\" type=\"settings\" layout=\"\">\n  <plugin>\n   <vrayplugin version=\"7\" type=\"settings\" name=\"SettingsImageFilter\">\n    <parameters>\n     <parameter handler=\"default\" listType=\"none\" type=\"bool\" name=\"on\" label=\"On\">\n      <value>1</value>\n     </parameter>\n     <parameter handler=\"ComboBoxHandler\" listType=\"none\" type=\"integer\" name=\"type\" label=\"Type\">\n      <value>5</value>\n     </parameter>\n     <parameter handler=\"default\" listType=\"none\" type=\"float\" name=\"size\" label=\"Size\">\n      <value>1.500000</value>\n     </parameter>\n    </parameters>\n   </vrayplugin>\n  </plugin>\n </Asset>\n</Assets>\n"
                                           "/SettingsDMCGI",
                                           "<Assets>\n <Asset renderer=\"vray\" url=\"/SettingsDMCGI\" type=\"settings\" layout=\"\">\n  <plugin>\n   <vrayplugin version=\"7\" type=\"settings\" name=\"SettingsDMCGI\">\n    <parameters>\n     <parameter handler=\"default\" listType=\"none\" type=\"integer\" name=\"subdivs\" label=\"Subdivs\">\n      <value>8</value>\n     </parameter>\n     <parameter handler=\"default\" listType=\"none\" type=\"integer\" name=\"depth\" label=\"Bounces\">\n      <value>3</value>\n     </parameter>\n    </parameters>\n   </vrayplugin>\n  </plugin>\n </Asset>\n</Assets>\n"
                                           *********** WAS TRUNCATED TO  FIT NodeBB ********
                                           "/SettingsVFBChannels",
                                           "<Assets>\n <Asset renderer=\"vray\" url=\"/SettingsVFBChannels\" type=\"settings\" layout=\"\">\n  <plugin>\n   <vrayplugin version=\"7\" type=\"settings\" name=\"SettingsVFBChannels\">\n    <parameters>\n     <parameter handler=\"default\" listType=\"none\" type=\"bool\" name=\"zdepth_clamp\" label=\"Clamp\">\n      <value>0</value>\n     </parameter>\n     <parameter handler=\"default\" listType=\"none\" type=\"float\" name=\"zdepth_white\" label=\"White\">\n      <value>1500.000000</value>\n     </parameter>\n     <parameter isUserData=\"1\" handler=\"default\" listType=\"none\" type=\"bool\" name=\"zdepth_set_from_camera\" label=\"Set from camera\">\n      <value>1</value>\n     </parameter>\n     <parameter isUserData=\"1\" handler=\"RenderChannelHandler\" listType=\"none\" type=\"list\" name=\"other_channels\" label=\"Other channels\">\n      <value>\n       <list/>\n      </value>\n     </parameter>\n     <parameter handler=\"default\" listType=\"none\" type=\"float\" name=\"zdepth_black\" label=\"Black\">\n      <value>0.001000</value>\n     </parameter>\n     <parameter handler=\"ListBoxMultiSelectHandler\" listType=\"string\" type=\"list\" name=\"channel_names\" label=\"VFB channels\">\n      <value>\n       <list>\n        <entry>RGB color</entry>\n        <entry>Alpha</entry>\n       </list>\n      </value>\n     </parameter>\n     <parameter handler=\"default\" listType=\"none\" type=\"integer\" name=\"unfiltered_fragment_method\" label=\"unfiltered_fragment_method\">\n      <value>0</value>\n     </parameter>\n    </parameters>\n   </vrayplugin>\n  </plugin>\n </Asset>\n</Assets>\n"
                                           "/SettingsDMCSampler",
                                           "<Assets>\n <Asset renderer=\"vray\" url=\"/SettingsDMCSampler\" type=\"settings\" layout=\"\">\n  <plugin>\n   <vrayplugin version=\"7\" type=\"settings\" name=\"SettingsDMCSampler\">\n    <parameters>\n     <parameter handler=\"default\" listType=\"none\" type=\"integer\" name=\"adaptive_min_samples\" label=\"Min samples\">\n      <value>8</value>\n     </parameter>\n     <parameter handler=\"default\" listType=\"none\" type=\"float\" name=\"adaptive_amount\" label=\"Adaptive amount\">\n      <value>0.850000</value>\n     </parameter>\n     <parameter handler=\"ComboBoxHandler\" listType=\"none\" type=\"integer\" name=\"path_sampler_type\" label=\"Path sampler\">\n      <value>2</value>\n     </parameter>\n     <parameter handler=\"default\" listType=\"none\" type=\"float\" name=\"subdivs_mult\" label=\"Global subdivs mult\">\n      <value>1.000000</value>\n     </parameter>\n     <parameter handler=\"default\" listType=\"none\" type=\"float\" name=\"adaptive_threshold\" label=\"Noise threshold\">\n      <value>0.010000</value>\n     </parameter>\n     <parameter handler=\"default\" listType=\"none\" type=\"bool\" name=\"time_dependent\" label=\"time_dependent\">\n      <value>0</value>\n     </parameter>\n    </parameters>\n   </vrayplugin>\n  </plugin>\n </Asset>\n</Assets>\n"
                                           "/SettingsOptions",
                                           "<Assets>\n <Asset renderer=\"vray\" url=\"/SettingsOptions\" type=\"settings\" layout=\"\">\n  <plugin>\n   <vrayplugin version=\"7\" type=\"settings\" name=\"SettingsOptions\">\n    <parameters>\n     <parameter handler=\"default\" listType=\"none\" type=\"bool\" name=\"light_doDefaultLights\" label=\"Default lights\">\n      <value>0</value>\n     </parameter>\n     <parameter isUserData=\"1\" handler=\"default\" listType=\"none\" type=\"bool\" name=\"batch_render\" label=\"Batch render\">\n      <value>0</value>\n     </parameter>\n     <parameter handler=\"default\" listType=\"none\" type=\"bool\" name=\"light_doLights\" label=\"Lights\">\n      <value>1</value>\n     </parameter>\n     <parameter handler=\"default\" listType=\"none\" type=\"bool\" name=\"light_onlyGI\" label=\"Show GI only\">\n      <value>0</value>\n     </parameter>\n     <parameter handler=\"default\" listType=\"none\" type=\"integer\" name=\"mtl_maxDepth\" label=\"Max depth\">\n      <value>5</value>\n     </parameter>\n     <parameter handler=\"default\" listType=\"none\" type=\"bool\" name=\"misc_transferAssets\" label=\"Transfer assets\">\n      <value>1</value>\n     </parameter>\n     <parameter handler=\"default\" listType=\"none\" type=\"bool\" name=\"misc_lowThreadPriority\" label=\"Low thread priority\">\n      <value>1</value>\n     </parameter>\n     <parameter handler=\"default\" listType=\"none\" type=\"bool\" name=\"misc_abortOnMissingAsset\" label=\"Abort on missing asset\">\n      <value>1</value>\n     </parameter>\n     <parameter handler=\"default\" listType=\"none\" type=\"bool\" name=\"misc_useCachedAssets\" label=\"Use cached assets\">\n      <value>1</value>\n     </parameter>\n     <parameter handler=\"default\" listType=\"none\" type=\"bool\" name=\"geom_backfaceCull\" label=\"Force back face culling\">\n      <value>0</value>\n     </parameter>\n     <parameter handler=\"default\" listType=\"none\" type=\"integer\" name=\"mtl_transpMaxLevels\" label=\"Max transp levels\">\n      <value>50</value>\n     </parameter>\n     <parameter handler=\"default\" listType=\"none\" type=\"float\" name=\"ray_bias\" label=\"Secondary ray bias\">\n      <value>0.001000</value>\n     </parameter>\n     <parameter handler=\"default\" listType=\"none\" type=\"bool\" name=\"mtl_glossy\" label=\"Glossy effects\">\n      <value>1</value>\n     </parameter>\n     <parameter handler=\"default\" listType=\"none\" type=\"bool\" name=\"light_doHiddenLights\" label=\"Hidden lights\">\n      <value>0</value>\n     </parameter>\n     <parameter handler=\"default\" listType=\"none\" type=\"bool\" name=\"geom_doHidden\" label=\"Hidden geom\">\n      <value>0</value>\n     </parameter>\n     <parameter handler=\"default\" listType=\"none\" type=\"bool\" name=\"mtl_uninvertedNormalBump\" label=\"Uninverted normal bump\">\n      <value>0</value>\n     </parameter>\n     <parameter handler=\"default\" listType=\"none\" type=\"bool\" name=\"geom_displacement\" label=\"Displacement\">\n      <value>1</value>\n     </parameter>\n     <parameter handler=\"default\" listType=\"none\" type=\"bool\" name=\"mtl_doMaps\" label=\"Maps\">\n      <value>1</value>\n     </parameter>\n     <parameter handler=\"default\" listType=\"none\" type=\"bool\" name=\"mtl_reflectionRefraction\" label=\"Reflection/refraction\">\n      <value>1</value>\n     </parameter>\n     <parameter handler=\"default\" listType=\"none\" type=\"bool\" name=\"mtl_filterMaps\" label=\"Filter maps\">\n      <value>1</value>\n     </parameter>\n     <parameter handler=\"default\" listType=\"none\" type=\"bool\" name=\"mtl_override_on\" label=\"Override materials\">\n      <value>0</value>\n     </parameter>\n     <parameter handler=\"default\" listType=\"none\" type=\"bool\" name=\"mtl_limitDepth\" label=\"Max depth\">\n      <value>0</value>\n     </parameter>\n     <parameter handler=\"default\" listType=\"none\" type=\"bool\" name=\"mtl_filterMapsForSecondaryRays\" label=\"Filter maps for GI\">\n      <value>0</value>\n     </parameter>\n     <parameter handler=\"default\" listType=\"none\" type=\"float\" name=\"mtl_transpCutoff\" label=\"Transp cutoff\">\n      <value>0.001000</value>\n     </parameter>\n     <parameter isUserData=\"1\" handler=\"default\" listType=\"none\" type=\"color\" name=\"mtl_override_color\" label=\"Override color\">\n      <value>\n       <r>0.784314</r>\n       <g>0.784314</g>\n       <b>0.784314</b>\n      </value>\n     </parameter>\n     <parameter handler=\"default\" listType=\"none\" type=\"bool\" name=\"gi_dontRenderImage\" label=\"Don't render final image\">\n      <value>0</value>\n     </parameter>\n     <parameter handler=\"default\" listType=\"none\" type=\"bool\" name=\"light_doShadows\" label=\"Shadows\">\n      <value>1</value>\n     </parameter>\n     <parameter isUserData=\"1\" handler=\"default\" listType=\"none\" type=\"bool\" name=\"show_progress_window\" label=\"Progress window\">\n      <value>1</value>\n     </parameter>\n    </parameters>\n   </vrayplugin>\n  </plugin>\n </Asset>\n</Assets>\n"
                                           "/SettingsIrradianceMap",
                                           "<Assets>\n <Asset renderer=\"vray\" url=\"/SettingsIrradianceMap\" type=\"settings\" layout=\"\">\n  <plugin>\n   <vrayplugin version=\"7\" type=\"settings\" name=\"SettingsIrradianceMap\">\n    <parameters>\n     <parameter handler=\"default\" listType=\"none\" type=\"integer\" name=\"subdivs\" label=\"HSph. subdivs\">\n      <value>50</value>\n     </parameter>\n     <parameter handler=\"FileBrowserHandler\" listType=\"none\" type=\"string\" name=\"file\" label=\"File\">\n      <value></value>\n     </parameter>\n     <parameter handler=\"default\" listType=\"none\" type=\"bool\" name=\"auto_save\" label=\"Auto save\">\n      <value>0</value>\n     </parameter>\n     <parameter handler=\"ComboBoxHandler\" listType=\"none\" type=\"integer\" name=\"lookup_mode\" label=\"Sample lookup\">\n      <value>3</value>\n     </parameter>\n     <parameter handler=\"default\" listType=\"none\" type=\"bool\" name=\"show_calc_phase\" label=\"Show calc phase\">\n      <value>1</value>\n     </parameter>\n     <parameter handler=\"default\" listType=\"none\" type=\"bool\" name=\"multiple_views\" label=\"Use camera path\">\n      <value>0</value>\n     </parameter>\n     <parameter handler=\"default\" listType=\"none\" type=\"float\" name=\"detail_radius\" label=\"Radius\">\n      <value>60.000000</value>\n     </parameter>\n     <parameter handler=\"default\" listType=\"none\" type=\"float\" name=\"color_threshold\" label=\"Clr thresh\">\n      <value>0.400000</value>\n     </parameter>\n     <parameter handler=\"ComboBoxHandler\" listType=\"none\" type=\"integer\" name=\"interpolation_mode\" label=\"Interpolation type\">\n      <value>1</value>\n     </parameter>\n     <parameter handler=\"CheckBoxHandler\" listType=\"none\" type=\"integer\" name=\"randomize_samples\" label=\"Randomize samples\">\n      <value>1</value>\n     </parameter>\n     <parameter handler=\"default\" listType=\"none\" type=\"integer\" name=\"max_rate\" label=\"Max rate\">\n      <value>-2</value>\n     </parameter>\n     <parameter handler=\"FileBrowserHandler\" listType=\"none\" type=\"string\" name=\"auto_save_file\" label=\"Auto save file\">\n      <value></value>\n     </parameter>\n     <parameter handler=\"default\" listType=\"none\" type=\"bool\" name=\"show_samples\" label=\"Show samples\">\n      <value>0</value>\n     </parameter>\n     <parameter handler=\"default\" listType=\"none\" type=\"bool\" name=\"show_direct_light\" label=\"Show direct light\">\n      <value>1</value>\n     </parameter>\n     <parameter handler=\"default\" listType=\"none\" type=\"bool\" name=\"check_sample_visibility\" label=\"Check sample visibility\">\n      <value>0</value>\n     </parameter>\n     <parameter handler=\"default\" listType=\"none\" type=\"integer\" name=\"min_rate\" label=\"Min rate\">\n      <value>-3</value>\n     </parameter>\n     <parameter handler=\"default\" listType=\"none\" type=\"float\" name=\"distance_threshold\" label=\"Dist thresh\">\n      <value>0.100000</value>\n     </parameter>\n     <parameter handler=\"default\" listType=\"none\" type=\"float\" name=\"normal_threshold\" label=\"Nrm Thresh\">\n      <value>0.300000</value>\n     </parameter>\n     <parameter handler=\"default\" listType=\"none\" type=\"float\" name=\"detail_subdivs_mult\" label=\"Subdivs mult\">\n      <value>0.300000</value>\n     </parameter>\n     <parameter handler=\"default\" listType=\"none\" type=\"integer\" name=\"interp_samples\" label=\"Interp. samples\">\n      <value>20</value>\n     </parameter>\n     <parameter handler=\"default\" listType=\"none\" type=\"integer\" name=\"interp_frames\" label=\"Interp. frames\">\n      <value>2</value>\n     </parameter>\n     <parameter handler=\"default\" listType=\"none\" type=\"bool\" name=\"multipass\" label=\"Multipass\">\n      <value>1</value>\n     </parameter>\n     <parameter handler=\"default\" listType=\"none\" type=\"integer\" name=\"calc_interp_samples\" label=\"Calc pass interp samples\">\n      <value>15</value>\n     </parameter>\n     <parameter handler=\"ComboBoxHandler\" listType=\"none\" type=\"integer\" name=\"detail_scale\" label=\"Scale\">\n      <value>0</value>\n     </parameter>\n     <parameter handler=\"default\" listType=\"none\" type=\"bool\" name=\"dont_delete\" label=\"Don't delete\">\n      <value>1</value>\n     </parameter>\n     <parameter handler=\"default\" listType=\"none\" type=\"bool\" name=\"detail_enhancement\" label=\"On\">\n      <value>0</value>\n     </parameter>\n     <parameter handler=\"ComboBoxHandler\" listType=\"none\" type=\"integer\" name=\"mode\" label=\"Mode\">\n      <value>0</value>\n     </parameter>\n    </parameters>\n   </vrayplugin>\n  </plugin>\n </Asset>\n</Assets>\n"
                                           "/SettingsEnvironment",
                                           "<Assets>\n <Asset renderer=\"vray\" url=\"/SunLight\" type=\"light\" layout=\"\">\n  <plugin>\n   <vrayplugin version=\"7\" type=\"light\" name=\"SunLight\">\n    <parameters>\n     <parameter handler=\"default\" listType=\"none\" type=\"color\" name=\"shadow_color\" label=\"Color\">\n      <value>\n       <r>0.000000</r>\n       <g>0.000000</g>\n       <b>0.000000</b>\n      </value>\n     </parameter>\n     <parameter handler=\"default\" listType=\"none\" type=\"float\" name=\"causticMult\" label=\"Caustic Mult\">\n      <value>1.000000</value>\n     </parameter>\n     <parameter handler=\"PluginListPicker\" listType=\"none\" type=\"list\" name=\"channels_specular\" label=\"Specular\">\n      <value>\n       <list/>\n      </value>\n     </parameter>\n     <parameter handler=\"PluginListPicker\" listType=\"none\" type=\"list\" name=\"channels\" label=\"Light result\">\n      <value>\n       <list/>\n      </value>\n     </parameter>\n     <parameter handler=\"default\" listType=\"none\" type=\"bool\" name=\"invisible\" label=\"Invisible\">\n      <value>1</value>\n     </parameter>\n     <parameter handler=\"default\" listType=\"none\" type=\"bool\" name=\"affectDiffuse\" label=\"Affect Diffuse\">\n      <value>1</value>\n     </parameter>\n     <parameter handler=\"default\" listType=\"none\" type=\"float\" name=\"size_multiplier\" label=\"Size\">\n      <value>1.000000</value>\n     </parameter>\n     <parameter handler=\"default\" listType=\"none\" type=\"integer\" name=\"causticSubdivs\" label=\"Caustic Subdivs\">\n      <value>1000</value>\n     </parameter>\n     <parameter handler=\"default\" listType=\"none\" type=\"transform\" name=\"transform\" label=\"transform\">\n      <value>\n       <vector>\n        <x>1.000000</x>\n        <y>0.000000</y>\n        <z>0.000000</z>\n       </vector>\n       <vector>\n        <x>0.000000</x>\n        <y>1.000000</y>\n        <z>0.000000</z>\n       </vector>\n       <vector>\n        <x>0.000000</x>\n        <y>0.000000</y>\n        <z>1.000000</z>\n       </vector>\n       <vector>\n        <x>0.000000</x>\n        <y>0.000000</y>\n        <z>0.000000</z>\n       </vector>\n      </value>\n     </parameter>\n     <parameter handler=\"default\" listType=\"none\" type=\"bool\" name=\"atmos_shadows\" label=\"Atmos Shadows\">\n      <value>1</value>\n     </parameter>\n     <parameter handler=\"default\" listType=\"none\" type=\"float\" name=\"water_vapour\" label=\"Water Vapor\">\n      <value>2.000000</value>\n     </parameter>\n     <parameter handler=\"PluginListPicker\" listType=\"none\" type=\"list\" name=\"channels_raw\" label=\"Raw light\">\n      <value>\n       <list/>\n      </value>\n     </parameter>\n     <parameter handler=\"default\" listType=\"none\" type=\"float\" name=\"intensity_multiplier\" label=\"Intensity\">\n      <value>1.000000</value>\n     </parameter>\n     <parameter handler=\"default\" listType=\"none\" type=\"integer\" name=\"photonSubdivs\" label=\"Photon Subdivs\">\n      <value>500</value>\n     </parameter>\n     <parameter handler=\"default\" listType=\"none\" type=\"float\" name=\"diffuseMult\" label=\"Diffuse Mult\">\n      <value>1.000000</value>\n     </parameter>\n     <parameter handler=\"default\" listType=\"none\" type=\"acolor texture\" name=\"shadow_color_tex\" label=\"shadow_color_tex\">\n      <value></value>\n     </parameter>\n     <parameter handler=\"ComboBoxHandler\" listType=\"none\" type=\"integer\" name=\"sky_model\" label=\"Sky Model\">\n      <value>1</value>\n     </parameter>\n     <parameter handler=\"default\" listType=\"none\" type=\"float\" name=\"shadowBias\" label=\"Bias\">\n      <value>0.000000</value>\n     </parameter>\n     <parameter handler=\"default\" listType=\"none\" type=\"bool\" name=\"shadows\" label=\"On\">\n      <value>1</value>\n     </parameter>\n     <parameter handler=\"default\" listType=\"none\" type=\"float\" name=\"horiz_illum\" label=\"Horizon Illum.\">\n      <value>25000.000000</value>\n     </parameter>\n     <parameter handler=\"default\" listType=\"none\" type=\"vector\" name=\"up_vector\" label=\"up_vector\">\n      <value>\n       <x>0.000000</x>\n       <y>0.000000</y>\n       <z>1.000000</z>\n      </value>\n     </parameter>\n     <parameter handler=\"default\" listType=\"none\" type=\"float\" name=\"photon_radius\" label=\"Photon Radius\">\n      <value>50.000000</value>\n     </parameter>\n     <parameter handler=\"default\" listType=\"none\" type=\"integer\" name=\"shadow_subdivs\" label=\"Subdivs\">\n      <value>8</value>\n     </parameter>\n     <parameter handler=\"default\" listType=\"none\" type=\"bool\" name=\"enabled\" label=\"Enabled\">\n      <value>1</value>\n     </parameter>\n     <parameter handler=\"default\" listType=\"none\" type=\"float\" name=\"ozone\" label=\"Ozone\">\n      <value>0.350000</value>\n     </parameter>\n     <parameter handler=\"default\" listType=\"none\" type=\"float\" name=\"turbidity\" label=\"Turbidity\">\n      <value>3.000000</value>\n     </parameter>\n     <parameter handler=\"default\" listType=\"none\" type=\"bool\" name=\"affectSpecular\" label=\"Affect Specular\">\n      <value>1</value>\n     </parameter>\n     <parameter handler=\"default\" listType=\"none\" type=\"transform\" name=\"target_transform\" label=\"target_transform\">\n      <value>\n       <vector>\n        <x>1.000000</x>\n        <y>0.000000</y>\n        <z>0.000000</z>\n       </vector>\n       <vector>\n        <x>0.000000</x>\n        <y>1.000000</y>\n        <z>0.000000</z>\n       </vector>\n       <vector>\n        <x>0.000000</x>\n        <y>0.000000</y>\n        <z>1.000000</z>\n       </vector>\n       <vector>\n        <x>0.000000</x>\n        <y>0.000000</y>\n        <z>0.000000</z>\n       </vector>\n      </value>\n     </parameter>\n     <parameter handler=\"PluginListPicker\" listType=\"none\" type=\"list\" name=\"channels_diffuse\" label=\"Diffuse\">\n      <value>\n       <list/>\n      </value>\n     </parameter>\n    </parameters>\n   </vrayplugin>\n  </plugin>\n </Asset>\n <Asset renderer=\"vray\" url=\"/SettingsEnvironment/Texture\" type=\"texture\" layout=\"\">\n  <plugin>\n   <vrayplugin version=\"7\" type=\"texture\" name=\"TexSky\">\n    <parameters>\n     <parameter handler=\"default\" listType=\"none\" type=\"float\" name=\"size_multiplier\" label=\"Size Mult.\">\n      <value>1.000000</value>\n     </parameter>\n     <parameter handler=\"default\" listType=\"none\" type=\"float\" name=\"horiz_illum\" label=\"Horizon Illum.\">\n      <value>25000.000000</value>\n     </parameter>\n     <parameter handler=\"default\" listType=\"none\" type=\"vector\" name=\"up_vector\" label=\"Up Vector\">\n      <value>\n       <x>0.000000</x>\n       <y>0.000000</y>\n       <z>1.000000</z>\n      </value>\n     </parameter>\n     <parameter handler=\"SunPickerHandler\" listType=\"none\" type=\"plugin\" name=\"sun\" label=\"Sun\">\n      <value>/SunLight</value>\n     </parameter>\n     <parameter handler=\"default\" listType=\"none\" type=\"transform\" name=\"transform\" label=\"transform\">\n      <value>\n       <vector>\n        <x>1.000000</x>\n        <y>0.000000</y>\n        <z>0.000000</z>\n       </vector>\n       <vector>\n        <x>0.000000</x>\n        <y>1.000000</y>\n        <z>0.000000</z>\n       </vector>\n       <vector>\n        <x>0.000000</x>\n        <y>0.000000</y>\n        <z>1.000000</z>\n       </vector>\n       <vector>\n        <x>0.000000</x>\n        <y>0.000000</y>\n        <z>0.000000</z>\n       </vector>\n      </value>\n     </parameter>\n     <parameter handler=\"default\" listType=\"none\" type=\"float\" name=\"ozone\" label=\"Ozone\">\n      <value>0.350000</value>\n     </parameter>\n     <parameter handler=\"default\" listType=\"none\" type=\"bool\" name=\"invisible\" label=\"Invisible\">\n      <value>0</value>\n     </parameter>\n     <parameter handler=\"default\" listType=\"none\" type=\"float\" name=\"water_vapour\" label=\"Water Vapor\">\n      <value>2.000000</value>\n     </parameter>\n     <parameter handler=\"ComboBoxHandler\" listType=\"none\" type=\"integer\" name=\"sky_model\" label=\"Sky Model\">\n      <value>0</value>\n     </parameter>\n     <parameter handler=\"default\" listType=\"none\" type=\"float\" name=\"turbidity\" label=\"Turbidity\">\n      <value>3.000000</value>\n     </parameter>\n     <parameter handler=\"default\" listType=\"none\" type=\"float\" name=\"intensity_multiplier\" label=\"Sky Brightness\">\n      <value>1.000000</value>\n     </parameter>\n     <parameter handler=\"default\" listType=\"none\" type=\"transform\" name=\"target_transform\" label=\"target_transform\">\n      <value>\n       <vector>\n        <x>1.000000</x>\n        <y>0.000000</y>\n        <z>0.000000</z>\n       </vector>\n       <vector>\n        <x>0.000000</x>\n        <y>1.000000</y>\n        <z>0.000000</z>\n       </vector>\n       <vector>\n        <x>0.000000</x>\n        <y>0.000000</y>\n        <z>1.000000</z>\n       </vector>\n       <vector>\n        <x>0.000000</x>\n        <y>0.000000</y>\n        <z>0.000000</z>\n       </vector>\n      </value>\n     </parameter>\n    </parameters>\n   </vrayplugin>\n  </plugin>\n </Asset>\n <Asset renderer=\"vray\" url=\"/SettingsEnvironment/gi_tex\" type=\"texture\" layout=\"\">\n  <plugin>\n   <vrayplugin version=\"7\" type=\"texture\" name=\"TexAColorOp\">\n    <parameters>\n     <parameter handler=\"default\" listType=\"none\" type=\"float texture\" name=\"result_alpha\" label=\"Alpha\">\n      <value></value>\n     </parameter>\n     <parameter handler=\"default\" listType=\"none\" type=\"acolor texture\" name=\"color_b\" label=\"Color B\">\n      <value></value>\n     </parameter>\n     <parameter handler=\"default\" listType=\"none\" type=\"acolor texture\" name=\"color_a\" label=\"Color A\">\n      <value>/SettingsEnvironment/Texture</value>\n     </parameter>\n     <parameter handler=\"default\" listType=\"none\" type=\"float texture\" name=\"mult_a\" label=\"Mult A\">\n      <value>1.000000</value>\n     </parameter>\n     <parameter handler=\"ComboBoxHandler\" listType=\"none\" type=\"integer\" name=\"mode\" label=\"Mode\">\n      <value>0</value>\n     </parameter>\n     <parameter handler=\"default\" listType=\"none\" type=\"float texture\" name=\"mult_b\" label=\"Mult B\">\n      <value></value>\n     </parameter>\n    </parameters>\n   </vrayplugin>\n  </plugin>\n </Asset>\n <Asset renderer=\"vray\" url=\"/SettingsEnvironment/Texture1\" type=\"texture\" layout=\"\">\n  <plugin>\n   <vrayplugin version=\"7\" type=\"texture\" name=\"TexSky\">\n    <parameters>\n     <parameter handler=\"default\" listType=\"none\" type=\"float\" name=\"size_multiplier\" label=\"Size Mult.\">\n      <value>1.000000</value>\n     </parameter>\n     <parameter handler=\"default\" listType=\"none\" type=\"float\" name=\"horiz_illum\" label=\"Horizon Illum.\">\n      <value>25000.000000</value>\n     </parameter>\n     <parameter handler=\"default\" listType=\"none\" type=\"vector\" name=\"up_vector\" label=\"Up Vector\">\n      <value>\n       <x>0.000000</x>\n       <y>0.000000</y>\n       <z>1.000000</z>\n      </value>\n     </parameter>\n     <parameter handler=\"SunPickerHandler\" listType=\"none\" type=\"plugin\" name=\"sun\" label=\"Sun\">\n      <value>/SunLight</value>\n     </parameter>\n     <parameter handler=\"default\" listType=\"none\" type=\"transform\" name=\"transform\" label=\"transform\">\n      <value>\n       <vector>\n        <x>1.000000</x>\n        <y>0.000000</y>\n        <z>0.000000</z>\n       </vector>\n       <vector>\n        <x>0.000000</x>\n        <y>1.000000</y>\n        <z>0.000000</z>\n       </vector>\n       <vector>\n        <x>0.000000</x>\n        <y>0.000000</y>\n        <z>1.000000</z>\n       </vector>\n       <vector>\n        <x>0.000000</x>\n        <y>0.000000</y>\n        <z>0.000000</z>\n       </vector>\n      </value>\n     </parameter>\n     <parameter handler=\"default\" listType=\"none\" type=\"float\" name=\"ozone\" label=\"Ozone\">\n      <value>0.350000</value>\n     </parameter>\n     <parameter handler=\"default\" listType=\"none\" type=\"bool\" name=\"invisible\" label=\"Invisible\">\n      <value>0</value>\n     </parameter>\n     <parameter handler=\"default\" listType=\"none\" type=\"float\" name=\"water_vapour\" label=\"Water Vapor\">\n      <value>2.000000</value>\n     </parameter>\n     <parameter handler=\"ComboBoxHandler\" listType=\"none\" type=\"integer\" name=\"sky_model\" label=\"Sky Model\">\n      <value>0</value>\n     </parameter>\n     <parameter handler=\"default\" listType=\"none\" type=\"float\" name=\"turbidity\" label=\"Turbidity\">\n      <value>3.000000</value>\n     </parameter>\n     <parameter handler=\"default\" listType=\"none\" type=\"float\" name=\"intensity_multiplier\" label=\"Sky Brightness\">\n      <value>1.000000</value>\n     </parameter>\n     <parameter handler=\"default\" listType=\"none\" type=\"transform\" name=\"target_transform\" label=\"target_transform\">\n      <value>\n       <vector>\n        <x>1.000000</x>\n        <y>0.000000</y>\n        <z>0.000000</z>\n       </vector>\n       <vector>\n        <x>0.000000</x>\n        <y>1.000000</y>\n        <z>0.000000</z>\n       </vector>\n       <vector>\n        <x>0.000000</x>\n        <y>0.000000</y>\n        <z>1.000000</z>\n       </vector>\n       <vector>\n        <x>0.000000</x>\n        <y>0.000000</y>\n        <z>0.000000</z>\n       </vector>\n      </value>\n     </parameter>\n    </parameters>\n   </vrayplugin>\n  </plugin>\n </Asset>\n <Asset renderer=\"vray\" url=\"/SettingsEnvironment/reflect_tex\" type=\"texture\" layout=\"\">\n  <plugin>\n   <vrayplugin version=\"7\" type=\"texture\" name=\"TexAColorOp\">\n    <parameters>\n     <parameter handler=\"default\" listType=\"none\" type=\"float texture\" name=\"result_alpha\" label=\"Alpha\">\n      <value></value>\n     </parameter>\n     <parameter handler=\"default\" listType=\"none\" type=\"acolor texture\" name=\"color_b\" label=\"Color B\">\n      <value></value>\n     </parameter>\n     <parameter handler=\"default\" listType=\"none\" type=\"acolor texture\" name=\"color_a\" label=\"Color A\">\n      <value>\n       <r>0.000000</r>\n       <g>0.000000</g>\n       <b>0.000000</b>\n      </value>\n     </parameter>\n     <parameter handler=\"default\" listType=\"none\" type=\"float texture\" name=\"mult_a\" label=\"Mult A\">\n      <value>1.000000</value>\n     </parameter>\n     <parameter handler=\"ComboBoxHandler\" listType=\"none\" type=\"integer\" name=\"mode\" label=\"Mode\">\n      <value>0</value>\n     </parameter>\n     <parameter handler=\"default\" listType=\"none\" type=\"float texture\" name=\"mult_b\" label=\"Mult B\">\n      <value></value>\n     </parameter>\n    </parameters>\n   </vrayplugin>\n  </plugin>\n </Asset>\n <Asset renderer=\"vray\" url=\"/SettingsEnvironment/refract_tex\" type=\"texture\" layout=\"\">\n  <plugin>\n   <vrayplugin version=\"7\" type=\"texture\" name=\"TexAColorOp\">\n    <parameters>\n     <parameter handler=\"default\" listType=\"none\" type=\"float texture\" name=\"result_alpha\" label=\"Alpha\">\n      <value></value>\n     </parameter>\n     <parameter handler=\"default\" listType=\"none\" type=\"acolor texture\" name=\"color_b\" label=\"Color B\">\n      <value></value>\n     </parameter>\n     <parameter handler=\"default\" listType=\"none\" type=\"acolor texture\" name=\"color_a\" label=\"Color A\">\n      <value>\n       <r>0.000000</r>\n       <g>0.000000</g>\n       <b>0.000000</b>\n      </value>\n     </parameter>\n     <parameter handler=\"default\" listType=\"none\" type=\"float texture\" name=\"mult_a\" label=\"Mult A\">\n      <value>1.000000</value>\n     </parameter>\n     <parameter handler=\"ComboBoxHandler\" listType=\"none\" type=\"integer\" name=\"mode\" label=\"Mode\">\n      <value>0</value>\n     </parameter>\n     <parameter handler=\"default\" listType=\"none\" type=\"float texture\" name=\"mult_b\" label=\"Mult B\">\n      <value></value>\n     </parameter>\n    </parameters>\n   </vrayplugin>\n  </plugin>\n </Asset>\n <Asset renderer=\"vray\" url=\"/SettingsEnvironment/bg_tex\" type=\"texture\" layout=\"\">\n  <plugin>\n   <vrayplugin version=\"7\" type=\"texture\" name=\"TexAColorOp\">\n    <parameters>\n     <parameter handler=\"default\" listType=\"none\" type=\"float texture\" name=\"result_alpha\" label=\"Alpha\">\n      <value></value>\n     </parameter>\n     <parameter handler=\"default\" listType=\"none\" type=\"acolor texture\" name=\"color_b\" label=\"Color B\">\n      <value></value>\n     </parameter>\n     <parameter handler=\"default\" listType=\"none\" type=\"acolor texture\" name=\"color_a\" label=\"Color A\">\n      <value>/SettingsEnvironment/Texture1</value>\n     </parameter>\n     <parameter handler=\"default\" listType=\"none\" type=\"float texture\" name=\"mult_a\" label=\"Mult A\">\n      <value>1.000000</value>\n     </parameter>\n     <parameter handler=\"ComboBoxHandler\" listType=\"none\" type=\"integer\" name=\"mode\" label=\"Mode\">\n      <value>0</value>\n     </parameter>\n     <parameter handler=\"default\" listType=\"none\" type=\"float texture\" name=\"mult_b\" label=\"Mult B\">\n      <value></value>\n     </parameter>\n    </parameters>\n   </vrayplugin>\n  </plugin>\n </Asset>\n <Asset renderer=\"vray\" url=\"/SettingsEnvironment\" type=\"settings\" layout=\"\">\n  <plugin>\n   <vrayplugin version=\"7\" type=\"settings\" name=\"SettingsEnvironment\">\n    <parameters>\n     <parameter isUserData=\"1\" handler=\"default\" listType=\"none\" type=\"acolor texture\" name=\"reflect_tex_tex\" label=\"Reflect Texture\">\n      <value></value>\n     </parameter>\n     <parameter handler=\"default\" listType=\"none\" type=\"integer\" name=\"num_environment_objects\" label=\"num_environment_objects\">\n      <value>0</value>\n     </parameter>\n     <parameter handler=\"default\" listType=\"none\" type=\"bool\" name=\"use_refract\" label=\"On\">\n      <value>0</value>\n     </parameter>\n     <parameter handler=\"default\" listType=\"none\" type=\"float\" name=\"refract_tex_mult\" label=\"Refract Texture Multiplier\">\n      <value>1.000000</value>\n     </parameter>\n     <parameter handler=\"default\" listType=\"none\" type=\"bool\" name=\"use_gi\" label=\"On\">\n      <value>1</value>\n     </parameter>\n     <parameter handler=\"default\" listType=\"none\" type=\"bool\" name=\"use_bg\" label=\"On\">\n      <value>1</value>\n     </parameter>\n     <parameter isUserData=\"1\" handler=\"default\" listType=\"none\" type=\"bool\" name=\"bg_tex_on\" label=\"On\">\n      <value>1</value>\n     </parameter>\n     <parameter handler=\"default\" listType=\"none\" type=\"float\" name=\"gi_tex_mult\" label=\"GI Texture Multiplier\">\n      <value>1.000000</value>\n     </parameter>\n     <parameter handler=\"ColorTexFrameHandler\" gammaCorrect=\"1\" listType=\"none\" type=\"acolor texture\" name=\"gi_tex\" label=\"GI Texture\">\n      <value>/SettingsEnvironment/gi_tex</value>\n     </parameter>\n     <parameter isUserData=\"1\" handler=\"default\" listType=\"none\" type=\"acolor texture\" name=\"bg_tex_tex\" label=\"Background Texture\">\n      <value>/SettingsEnvironment/Texture1</value>\n     </parameter>\n     <parameter isUserData=\"1\" handler=\"default\" listType=\"none\" type=\"color\" name=\"refract_color\" label=\"Refract color\">\n      <value>\n       <r>0.000000</r>\n       <g>0.000000</g>\n       <b>0.000000</b>\n      </value>\n     </parameter>\n     <parameter isUserData=\"1\" handler=\"default\" listType=\"none\" type=\"acolor texture\" name=\"gi_tex_tex\" label=\"GI Texture\">\n      <value>/SettingsEnvironment/Texture</value>\n     </parameter>\n     <parameter handler=\"default\" listType=\"none\" type=\"integer\" name=\"texture_multiplier_mode\" label=\"Texture multiplier mode\">\n      <value>0</value>\n     </parameter>\n     <parameter isUserData=\"1\" handler=\"default\" listType=\"none\" type=\"bool\" name=\"refract_tex_on\" label=\"On\">\n      <value>1</value>\n     </parameter>\n     <parameter isUserData=\"1\" handler=\"default\" listType=\"none\" type=\"color\" name=\"gi_color\" label=\"GI color\">\n      <value>\n       <r>0.800000</r>\n       <g>0.901961</g>\n       <b>1.000000</b>\n      </value>\n     </parameter>\n     <parameter handler=\"None\" listType=\"none\" type=\"plugin\" name=\"environment_volume\" label=\"Environment volume\">\n      <value></value>\n     </parameter>\n     <parameter isUserData=\"1\" handler=\"default\" listType=\"none\" type=\"color\" name=\"reflect_color\" label=\"Reflect color\">\n      <value>\n       <r>0.000000</r>\n       <g>0.000000</g>\n       <b>0.000000</b>\n      </value>\n     </parameter>\n     <parameter handler=\"default\" listType=\"none\" type=\"bool\" name=\"use_reflect\" label=\"On\">\n      <value>0</value>\n     </parameter>\n     <parameter isUserData=\"1\" handler=\"default\" listType=\"none\" type=\"color\" name=\"bg_color\" label=\"BG color\">\n      <value>\n       <r>0.000000</r>\n       <g>0.000000</g>\n       <b>0.000000</b>\n      </value>\n     </parameter>\n     <parameter handler=\"ColorTexFrameHandler\" gammaCorrect=\"1\" listType=\"none\" type=\"acolor texture\" name=\"reflect_tex\" label=\"Reflect Texture\">\n      <value>/SettingsEnvironment/reflect_tex</value>\n     </parameter>\n     <parameter isUserData=\"1\" handler=\"default\" listType=\"none\" type=\"acolor texture\" name=\"refract_tex_tex\" label=\"Refract Texture\">\n      <value></value>\n     </parameter>\n     <parameter isUserData=\"1\" handler=\"default\" listType=\"none\" type=\"bool\" name=\"reflect_tex_on\" label=\"On\">\n      <value>1</value>\n     </parameter>\n     <parameter handler=\"ColorTexFrameHandler\" gammaCorrect=\"1\" listType=\"none\" type=\"acolor texture\" name=\"refract_tex\" label=\"Refract Texture\">\n      <value>/SettingsEnvironment/refract_tex</value>\n     </parameter>\n     <parameter handler=\"default\" listType=\"none\" type=\"float\" name=\"reflect_tex_mult\" label=\"Reflect Texture Multiplier\">\n      <value>1.000000</value>\n     </parameter>\n     <parameter handler=\"default\" listType=\"none\" type=\"bool\" name=\"gi_tex_on\" label=\"On\">\n      <value>1</value>\n     </parameter>\n     <parameter handler=\"ColorTexFrameHandler\" gammaCorrect=\"1\" listType=\"none\" type=\"acolor texture\" name=\"bg_tex\" label=\"Background Texture\">\n      <value>/SettingsEnvironment/bg_tex</value>\n     </parameter>\n     <parameter handler=\"default\" listType=\"none\" type=\"float\" name=\"bg_tex_mult\" label=\"Background Texture Multiplier\">\n      <value>1.000000</value>\n     </parameter>\n    </parameters>\n   </vrayplugin>\n  </plugin>\n </Asset>\n</Assets>\n"
                                          these are in your file...
                                          you need a clean template without all of this...
                                          john
