    Generating coordinates with Ruby
    6 Posts 4 Posters 489 Views 4 Watching
    • K Offline
      kmk111890
      Hi, I'm looking for how to generates coordinate with an equation and connect the coordinates adding line or curve with ruby.
      My idea was
      ents = Sketchup.active_model.entities
      pt0 = [a,b,c]
      pt1 = [d,e,f]
      pt2 = [g,h,i]
      for k in 0...20
      x = eq*pt0.x + eq*pt1.x + eq*pt2.x
      y = eq*pt0.y + eq*pt1.y + eq*pt2.y
      z = eq*pt0.z + eq*pt1.z + eq*pt2.z
      pt3 = Geom;;Point3d.new(x, y, z)
      ents.add_line pt3
      pt0, pt1, pt2 are basic coordinates. 'eq' means random equation. We can add any equation with a variable 'k'
      I know there are some errors, but don't know how to fix it. I wish 21 different coordinates are generated from the 'for loop' and they connect each other to draw a line. Can you help me?
      • sdmitchS Offline
        sdmitch
        My idea was
        > pt0 = [a,b,c]
        > pt1 = [d,e,f]
        > pt2 = [g,h,i]
        > for k in 0...20
        > end
        > ents.add_line pt3
        The .add_line functions requires a start and end. Your code only has an end. The ents.add_line statement should be inside the For loop. If not, only the last "pair" will be used in the .add_line.
        http://sdmitch.blogspot.com/
          slbaumgartner
          In addition, if you gather the points into an Array you can use Entities#add_edges to create them all in one shot.
            Something like this:
            pt0 = [a, b, c]
            pt1 = [d, e, f]
            pt2 = [g, h, i]
            pt3 = Geom;;Point3d.new(0, 0, 0)
            pts = []
            for k in 0...20
                pts << pt3
            Sketchup.active_model.active_entities.add_edges(pts)
            Naturally you'll need to define the xyz value references a up to i, and the eq earlier on in the code...
            BUT is this example it currently makes a straight line, k is never used ?
            Is it actually eq ?
            If so then currently the points would just 'step' up by 1" each time !
            I suspect you somehow want to use pt3 iterated in the calculation [that's why I made it outside of the block before it starts changing] ?
            e.g. x = eq*pt0.x + eq*pt1.x + eq*pt2.x**+ eq*pt3.x**
            πŸ˜•
            • K Offline
              kmk111890
              Thank you, sdmitch and TIG. I could partly understand how i have to fix the codes, but not perfect because I showed you code roughly. Maybe, it would be better i show you what i'm doing now. I'm trying to add bezier curve to draw one simple shape. The equation for the quadratic bezier curve represents as shown below
              B(t) = (1-t)(1-t)P0+2(1-t)P1+(t)(t)P2
              With the equation, I tried to generate coordinates which are from the equation and wanted to use 'For loop'. hmmm It looked like i can make the codes by myself, but didn't work well
              Length = 1000
              angle = (60)/2
              angle2 = (45)/2
              pt0 = [0,0,0]
              pt1 = [Length.mm, 0, 0]
              aa = 80*0.01
              pt2 = pt1.transform(Geom;;Transformation.rotation(pt0,[0,-1,0],angle.degrees))
              pt3 = pt1.transform(Geom;;Transformation.rotation(pt0,[0,-1,0],angle2.degrees))
              pt4 = [Length.mm*aa, 0, 0]
              pt5 = pt4.transform(Geom;;Transformation.rotation(pt0,[0,-1,0],angle.degrees))
              arcarray = ents.add_arc [0,0,0], [1,0,0],[0,-1,0], Length.mm, 0, angle2.degrees
              arc = arcarray[0]
              arccurve = arc.curve
              verts = arccurve.vertices
              t1=0
              x6 = (1-(t1))*(1-(t1))*pt5.x+2*(1-(t1))*(t1)*pt2.x+(t1)*(t1)*pt3.x
              y6 = (1-(t1))*(1-(t1))*pt5.y+2*(1-(t1))*(t1)*pt2.y+(t1)*(t1)*pt3.y
              z6 = (1-(t1))*(1-(t1))*pt5.z+2*(1-(t1))*(t1)*pt2.z+(t1)*(t1)*pt3.z
              pt6 = Geom;;Point3d.new(x6, y6, z6)
              t2=0.2
              x7 = (1-(t2))*(1-(t2))*pt5.x+2*(1-(t2))*(t2)*pt2.x+(t2)*(t2)*pt3.x
              y7 = (1-(t2))*(1-(t2))*pt5.y+2*(1-(t2))*(t2)*pt2.y+(t2)*(t2)*pt3.y
              z7 = (1-(t2))*(1-(t2))*pt5.z+2*(1-(t2))*(t2)*pt2.z+(t2)*(t2)*pt3.z
              pt7 = Geom;;Point3d.new(x7, y7, z7)
              t3=0.4
              x8 = (1-(t3))*(1-(t3))*pt5.x+2*(1-(t3))*(t3)*pt2.x+(t3)*(t3)*pt3.x
              y8 = (1-(t3))*(1-(t3))*pt5.y+2*(1-(t3))*(t3)*pt2.y+(t3)*(t3)*pt3.y
              z8 = (1-(t3))*(1-(t3))*pt5.z+2*(1-(t3))*(t3)*pt2.z+(t3)*(t3)*pt3.z
              pt8 = Geom;;Point3d.new(x8, y8, z8)
              t4=0.6
              x9 = (1-(t4))*(1-(t4))*pt5.x+2*(1-(t4))*(t4)*pt2.x+(t4)*(t4)*pt3.x
              y9 = (1-(t4))*(1-(t4))*pt5.y+2*(1-(t4))*(t4)*pt2.y+(t4)*(t4)*pt3.y
              z9 = (1-(t4))*(1-(t4))*pt5.z+2*(1-(t4))*(t4)*pt2.z+(t4)*(t4)*pt3.z
              pt9 = Geom;;Point3d.new(x9, y9, z9)
              t5=0.8
              x10 = (1-(t5))*(1-(t5))*pt5.x+2*(1-(t5))*(t5)*pt2.x+(t5)*(t5)*pt3.x
              y10 = (1-(t5))*(1-(t5))*pt5.y+2*(1-(t5))*(t5)*pt2.y+(t5)*(t5)*pt3.y
              z10 = (1-(t5))*(1-(t5))*pt5.z+2*(1-(t5))*(t5)*pt2.z+(t5)*(t5)*pt3.z
              pt10 = Geom;;Point3d.new(x10, y10, z10)
              t6=1
              x11 = (1-(t6))*(1-(t6))*pt5.x+2*(1-(t6))*(t6)*pt2.x+(t6)*(t6)*pt3.x
              y11 = (1-(t6))*(1-(t6))*pt5.y+2*(1-(t6))*(t6)*pt2.y+(t6)*(t6)*pt3.y
              z11 = (1-(t6))*(1-(t6))*pt5.z+2*(1-(t6))*(t6)*pt2.z+(t6)*(t6)*pt3.z
              pt11 = Geom;;Point3d.new(x11, y11, z11)
              a = ents.add_line pt0, pt1
              b = ents.add_line pt0, pt5
              c = ents.add_curve pt0, pt6, pt7, pt8, pt9, pt10, pt11, pt1
              face = ents.add_face pt6, pt7, pt8, pt9, pt10, pt11, pt1, pt0
              path = ents.add_circle [Length,0,0], [-1,0,0], -Length
              face.followme path
              ents.erase_entities path
              face2 = ents.add_face verts
              path2 = ents.add_circle [Length,0,0], [-1,0,0], -Length
              face2.followme path2
              ents.erase_entities path2
              group=ents.add_group ents.to_a
              • sdmitchS Offline
                sdmitch
                This seems to work
                Length = 1000
                angle = (60)/2
                angle2 = (45)/2
                pt0 = [0,0,0]
                aa = 80*0.01
                arc = arcarray[0]
                pts=[];pts<<pt0
                0.step(1,0.2) do |t1|
                  x = (1-(t1))*(1-(t1))*pt5.x+2*(1-(t1))*(t1)*pt2.x+(t1)*(t1)*pt3.x
                  y = (1-(t1))*(1-(t1))*pt5.y+2*(1-(t1))*(t1)*pt2.y+(t1)*(t1)*pt3.y
                  z = (1-(t1))*(1-(t1))*pt5.z+2*(1-(t1))*(t1)*pt2.z+(t1)*(t1)*pt3.z
                  pts << Geom;;Point3d.new(x, y, z)
                pts<<pt1
                c = ents.add_curve pts
                face = ents.add_face pts
                face.followme path
