    Can't See all of DXF File
    12 Posts 4 Posters 789 Views 4 Watching
      BeePee
      I'm trying to load a .dxf file using my usual importer, FreeDXF v0.9.0. It normally works fine, but in this case I'm only seeing a part of the file in Sketchup.
      See the attachments for the .dxf file, what I see, and the full file in a CAD file viewer. Any help appreciated!
      Thanks, Brendan
      I only see part of this file, one of the plates with the round holes
      This is what I see
      This is the full file
      • HornOxxH Offline
        HornOxx
        Hi Brendan
        I have no idea, why your dxf-import didn´t work correct.
        Anyway, here is your imported dxf-file, saved as Skup 8-file...
        (I hope this file is ok and in the way you expect?)
        Regards
        10 HOLE REEDPLATES.skp
        never trust a skinny cook
          BeePee
          Thanks HornOxx! I've no idea either, but your conversion does the job, much appreciated!
          Still would like to know what the problem was, if anyone else can posit a suggestion.
          Cheers, Brendan
            BeePee
            OOps HornOxx, one more issue: I think your conversion may have used inches or some other large unit. These are harmonica reedplates, and the correct unit is millimetres.
            Any chance you could give it to me again in mm?
            Brendan
            • cottyC Offline
              cotty
              Brendan
              You can measure one known length and type in the right length to scale the model with the tape measure tool. (http://help.sketchup.com/de/article/95006 )
              my SketchUp gallery
              • HornOxxH Offline
                HornOxx
                Sorry, I didn´t even think about dimensioning 😳
                have switched to mm - hopefully it fits now ...
                10 HOLE REEDPLATES1.skp
                • HornOxxH Offline
                  HornOxx
                  Brendan
                  Thanks Cotty, for this reason I have added one unit in the current file
                  • cottyC Offline
                    cotty
                    The hint was meant for BeeBee, I'm sure you did know this 😉
                    my SketchUp gallery
                    • HornOxxH Offline
                      HornOxx
                      Ja! 😆
                        Jim
                        FreeDXF 0.9.0 is failing on 2 SPLINE entities in the .dxf file. I don't yet know the reason for the failure, but here is the import if we just ignore the splines.
                        (Yes, the TEXT and MTEXT parsing needs much work...)
                        10-hole-readplate-v13.skp
                          BeePee
                          Thanks everyone, this forum is brilliant!
                          Wow Jim, was all that extra info in there as well? I had no idea. No idea what a spline is either, but I'm glad you guys do!
                          BeePee
                            Jim
                            If it helps after so long, here's the model with the Simplified Chinese text intact.
                            reedplates-text.skp
