    Can't See all of DXF File
    12 Posts 4 Posters 1.0k Views 4 Watching
    • B
      BeePee
      Thanks HornOxx! I've no idea either, but your conversion does the job, much appreciated!
      Still would like to know what the problem was, if anyone else can posit a suggestion.
      Cheers, Brendan
      • B
        BeePee
        OOps HornOxx, one more issue: I think your conversion may have used inches or some other large unit. These are harmonica reedplates, and the correct unit is millimetres.
        Any chance you could give it to me again in mm?
        Brendan
        • cottyC
          cotty
          Brendan
          You can measure one known length and type in the right length to scale the model with the tape measure tool. (http://help.sketchup.com/de/article/95006 )
          my SketchUp gallery
          • HornOxxH
            HornOxx
            Sorry, I didn´t even think about dimensioning 😳
            have switched to mm - hopefully it fits now ...
            10 HOLE REEDPLATES1.skp
            never trust a skinny cook
            • HornOxxH
              HornOxx
              Brendan
              Thanks Cotty, for this reason I have added one unit in the current file
              • cottyC
                cotty
                The hint was meant for BeeBee, I'm sure you did know this 😉
                my SketchUp gallery
                • HornOxxH
                  HornOxx
                  Ja! 😆
                    Jim
                    FreeDXF 0.9.0 is failing on 2 SPLINE entities in the .dxf file. I don't yet know the reason for the failure, but here is the import if we just ignore the splines.
                    (Yes, the TEXT and MTEXT parsing needs much work...)
                    10-hole-readplate-v13.skp
                    • B
                      BeePee
                      Thanks everyone, this forum is brilliant!
                      Wow Jim, was all that extra info in there as well? I had no idea. No idea what a spline is either, but I'm glad you guys do!
                      BeePee
                        Jim
                        If it helps after so long, here's the model with the Simplified Chinese text intact.
                        reedplates-text.skp
