    Stretched Materials Appearing after rendering... PLEASE HELP
    renderpluginsextensions
    8 Posts 3 Posters 1.3k Views 3 Watching
      Mina Nady
      Hello,
      I am using Sketchup 2015 and v-ray 2.0 , and i have faced a problem so far i can't find a proper solution to it, i wish you guys have the solution.
      I am doing A Yacht club project for my portfolio , as far i went there was no problem , untill i put materials and rendered the project, i found that material like rocks , wood , tiles and any material unless glass sure , is beed stretched.I can't find a solution . I tried to divide the area to small parts , and nothing gone well.
      Anyone has a solution ?? please .... I'm in a dead need
      thanks in advance
      http://store2.up-00.com/2015-07/1436457865851.jpg
      http://store2.up-00.com/2015-07/1436457866063.jpgqq
        rspierenburg
        Can you post an example of the rendered texture so we can get a sense of how its being stretched?
        • FrederikF Offline
          Frederik
          Not sure why you've used a 3rd party provider to host the images...
          It's really easy to use the "Upload attachment" option here at the SCF...
          Your problem seem to be missing UV-mapping...
          You've applied a color to the surface and then applied a texture material in Vray...
          However, you don't UV-map a mesh simply by applying a color in SU...
          You can apply a texture material in SU and then you get the UV-maps applied and you'll be able to use a Vray texture material subsequently...
          Cheers
          Kim Frederik
            Mina Nady
            I am totally new to these forums , how can i upload photos here ? πŸ˜„
            • FrederikF Offline
              Frederik
              An image says more than a thousand words...
              Didn't the answer I provided help you in any way...?
              Cheers
              Kim Frederik
                Mina Nady
                Yes it helped a little πŸ˜„ nw i have a name , uv mapping , and i searched for uv mapping tools in google and i found sketchuv plugin , i am trying to use it nw.
                Thank you alot , isn't there any easier way to do the job ? It would be very hard to do that to every surface i have , especially for large Projects
                • FrederikF Offline
                  Frederik
                  UV-mapping is a very basic thing in 3D modeling, yet it seem to be one of the most important things, users don't really understand...
                  Just to get a brief explanation, I suggest you read this...
                  https://en.wikipedia.org/wiki/UV_mapping
                  You don't need to use a plugin to assign UV-coordinates to a surface in SketchUp...
                  Like I wrote...
                  Cheers
                  Kim Frederik
                    rspierenburg
                    Yes, basically Vray doesn't know how big to make your texture or in what direction to lay it because it uses SketchUp textures to determine that. And since a color has neither direction nor size it gets all messed up.
