    Lake home npr
    16 Posts 12 Posters 1.1k Views 12 Watching
    • pmolsonP Offline
      pmolson
      This was an interesting / fun project.
      The model was used for design developement and the final elevations were brought into acad for use in the construction docs. I will have to see if I can get the builder to let me use the final plans and if I can I will post.
      The model images are mine to use though and I like to share.
      01-front_watercolor-style.jpg02-birdseye.jpg03-right-side.jpg04-birdseye.jpg05-rear.jpg06-left.jpg07-left.jpg08-front.jpg09_front-elevation.jpg
      • alvisA Offline
        alvis
        home, sweet home... πŸ˜„
        beautiful country style home.
        • DanielD Offline
          Daniel
          Beautiful work, Paul.
          On the elevation image, the projection of the garage wing would be better illustrated with the shadows projected from the opposite side.
          My avatar is an anachronism.
          • HornOxxH Offline
            HornOxx
            Congratulations
            πŸ‘
            A fantastic, very detailed and accurate work - thanks for sharing this!
            How did you get this watercolor (aquarell?) look, specifically from the first image, which you have posted here? Is it one of SkUpΒ΄s default styles?
            never trust a skinny cook
            • pmolsonP Offline
              pmolson
              Daniel, You are correct, it would read better if the garage cast a shadow on to the house.
              I can't remember if it was the case on this one, but sometimes i am limited to certain sun angles because I am trying to have all the sides have decent shadows...kind of a balancing act.
              I so wish the Set north tool allowed one to store the north angle with a scene which would allow me to cheat and have the best shadow options (although fake) for each side of the model.
              Hornoxx,
              The style is a modified sanford hard pencil. One of the defaults I think.
              The first image I also applied a watercolor filter in photoshop.
              Beware though...The combination of sanford pencil with 3d trees and bushes and shadows on makes the model verrrrrrry heavvvvvyyyyy. This particular model is just a pig to work on when I have all the trees and bush layers on and sanford style applied.
              • jo-keJ Offline
                jo-ke
                Wow, beautyful project and presentation.
                http://www.zz7.de
                  Another really nice presentation, bloomin' well done.
                  • pmolsonP Offline
                    pmolson
                    Thanks you for the nice comments. I feel very lucky to have the opportunity to work on these elaborate projects.
                      roland joseph
                      Really nice style...beautiful place!
                      • GubermenschG Offline
                        Gubermensch
                        ^My thoughts, exactly
                        http://www.jacobgubler.com/
                        • boofredlayB Offline
                          boofredlay
                          Very well done. πŸ‘
                          • hellnbakH Offline
                            hellnbak
                            I know just what you mean.
                            Since I don't render I have to rely heavily on the shadows to make my models look decent. It can be a real pain in the butt sometimes.
                            I remember before I discovered Set North I used to have to rotate the entire model (many times) to try to find the best shadows. Now that was fun (NOT) πŸ˜†
                            Absolutely beautiful work, that's a house I could call home!
                            • pmolsonP Offline
                              pmolson
                              I wonder if it is not possible to create a plugin that would store the global sun position with a scene....I am guessing not or it would have been done already. I may pop over to the plug ins thread and inquire.
                              Thank you all for the positive feedback.
                              paul
                              • DanielD Offline
                                Daniel
                                If it was really important, I suppose the easiest way would be to save another copy of your model and change the solar orientation in it.
                                I can usually get decent shadows all around the building by changing the time of day and the date. Invariably, if I model with the correct orientation, however, at least one side of the building is always in shadow.
                                • pbacotP Offline
                                  Love the work Paul.
                                  There's a plugin by TIG for classic elevation shadows. I forget how it deals with North (in the northern hemisphere) or exactly what's included. I usually just don't bother to shadow north in elevations. (What I have most problem with is "shading" making oblique surfaces too dark for elevations).
                                  • Bryan KB Offline
                                    Gorgeous!
