    Shape Bender issue
    17 Posts 6 Posters 4.7k Views 6 Watching
    • hykenfreakH Offline
      hykenfreak
      I have searched the forums but nothing can provide an answer. Shape bender will not let me select the straight line after I have selected the component and clicked the Shape bender button. The line does not turn blue when I hover over it. When I try to click on it nothing happens. Thoughts?
      Failure is the fertilizer of success.
      • TIGT Online
        Please post the SKP with which you are having this issue...
        I suspect that you have some simple issue with the edge/curve location/orientation etc...
        We can fix it. πŸ€“
          hykenfreak
          https://www.dropbox.com/s/8lhf7oqbsb2d0uk/Cromer%27s%20NightLight.skp?dl=0
          The file was too large. But here's a link to my Dropbox. This is my first foray into Sketchup so I'm still trying to learn things (file compression included).
          • TIGT Online
            If you didn't have overlaid component-instances... and you used Model Info > Statistics > Purge Unused...
            It would get a lot smaller and be attachable, and more likely to get a response...
            I get no problems...
            Select the Object.
            Activate the Plugin.
            Pick the Line.
            Pick the Curve.
            After a second or two the bent replica appears...
              hykenfreak
              I will try that next time. Apologies. T have tried restarting Sketchup but it still does nothing. I don't know what the deal is. I may try reinstalling Shape Bender. The fact that it worked for you makes me think that something is wrong with my specific program (probably user error).
              • TIGT Online
                If you have the latest version of the Plugin installed and you follow the steps exactly as I outlined, then it should work just fine...
                πŸ˜•
                  hykenfreak
                  Turns out I had installed it improperly. Thanks for helping me narrow down the problem. It's working great now.
                  • W Offline
                    wilkes704
                    I'm having some of the same issues. I've reinstalled the newest version of shape bender. I have a straight line on the red axis, but it won't let me click on it. I've had the plugin work yesterday for me, so I am not sure what the issue is here.
                    Here is the error that the Ruby console threw when I double clicked on the straight line:
                    Error: #<NoMethodError: undefined method all_connected' for nil:NilClass> C:/Users/charles/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/clf_shape_bender/clf_shape_bender_data.rb:255:in line_picker'
                    C:/Users/charles/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/clf_shape_bender/clf_shape_bender_data.rb:187:in `onLButtonUp'
                    model.skp
                    • TIGT Online
                      @charles
                      At some point you have reset the model's axes.
                      That will break tools like Shape-Bender.
                      Hover over an axis away from other stuff.
                      Context-menu > Reset.
                      The original axis appear and the line etc are NOT parallel to the Red/X axis...
                      Rotate those to suit and then Shape-Bender WILL work as advertised...
                      πŸ˜’
                      • pbacotP Offline
                        Where else to get such exact and immediate help? Kudos TIG!
                        • TIGT Online
                          @charles
                          Additional advice...
                          Place the group/line/curve on the +ve quadrant of the axes...
                          And reverse the face in the group for tidiness...
                          • K Offline
                            keerthanadevi
                            I am having the same issue here
                            i have downloaded shape bender
                            but when i use the plugin to bend the model i am having trouble
                            when i select the line it doesn't turn blue even though i drew the line along red axis
                            it says " please select the line that is drawn on red axis"
                            i have been trying from yesterday
                            And the downloaded version is unsigned version
                            I am pulling my hair here, please help me!!!!
                            • K Offline
                              keerthanadevi
                              i have the very same issue
                              i recently downloaded shape bender unsigned version
                              after installing in sketchup it doesnt work properly
                              wen i select the straight line of the model it says "please select the line drawn on red axis"
                              i did draw the line along red axis
                              i am having this trouble since yesterday
                              plese help me out
                              • BoxB Offline
                                It's fairly clear in your screenshot that the edge under the shape and the shape itself are not aligned along the red axis.
                                • K Offline
                                  keerthanadevi
                                  No it still happens the same
                                  i have been working on this New model today
                                  i have grouped the model, now i want to turn that in to half circle that i have drawn nearby.
                                  Again it says the same "please select the line drawn on red axis"
                                  the line is not turning blue wen i select it
                                  here is the model of the image
                                  please help me figure out
                                  thank you.
                                  • TIGT Online
                                    Have you changed the axes ?
                                    If so reset them.
                                    Then draw a line along the X [red] axis...
                                    Try to preselect it, before running the tool ?
                                    • BoxB Offline
                                      Attach the model so we can check it rather than guessing.
