Is this Possible?
Hi~
I'm looking for a plugin as at the following picture.
Options -----
- Inputting Numbers
- Keep Original Outline, Yes or No
Do you know like this plugin or similar?
Please, help me...
Extrude-Tools Offset could do this - but in steps per set of edges, with some manual tidying up...
thank you, but I want to do it using plugin.
Perhaps you can have a look at (all) this thread:
http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=62177 -
But the Extrude-Tools Offset IS a plugin... doh!
Like this ? S4u-Frame by SuForYou
[quote="pilou"]Like this ? S4u-Frame by SuForYou
oh! Good...
Where can I download this plugin?
s4u frame V3.0.2 is Not free.
I want to download free version.
s4u frame v1.1 can't does as your work.
thank you.
You can download the trial and try it for 7 days and if you like it/need it you can purchase it for $7 .
So another possibility in all free!
Perpendicular faces Tools / Square By Chris Fullmer
Just clic extremity : input dimension of the square -
Curviloft by Fredo6 (middle icon on the video)
(Will be also possible with Extrude a Face along Edges by Tig but less practicable!
Select a face an a path and use this method
Select All, Menu Windows / Disable Smooth Edges
Solid Solver by Tig
Select All, Explode All, Select All, Intersect All, Make a Group then call Solid Solver
If you want only the surface, just select the top surface of the result!
That all!
PS If you use the mode XRay view, you will see that you have always the start path!
So take it and move it on the top surface!
Pilou, how do you make these GIFs? Is it complicated?
Ultra easy and free!
Download it only from this site! (Manual on the site
, or in French on my site!
)[web 100%,100:37sfhczj]http://blog.bahraniapps.com/wp-content/uploads/2013/03/gifcamyoyo.gif[/web:37sfhczj]
profile builder doing this,too..for the old version 1.x you can find a free version
Register LoginAdvertisement
