    Is there pluging for expanding/making face along line/edges?
    41 Posts 12 Posters 3.0k Views 12 Watching
    • JQLJ Offline
      JQL
      @pilou said:
      Is your offset capable of expanding edges to the end of the associated face too?
      Can you put an image of this ?
      Edgetools split face...
      www.casca.pt
      Visit us on facebook!
        This sort of things ?
        • JQLJ Offline
          JQL
          That sort of things. Thanks Pilou, my gif making abilities were ruined with this 4k monitor.
          www.casca.pt
          • pbacotP Offline
            Edge tools split face is great but what OP is asking for is double offsets and removal of the original edges, also for working on curves which split face can't help with much. The second part--removal of original edge--is not too slow manually.
            This action seems so common. In making facades, doors, windows cabinets, paneling etc. where all is needed is a "reveal" or joint or, in this case a ridge. So easy to lay out the defining edges, next step is to give those edges "width" for 3d use.
            I'd leave out the perimeter action as that seems a different action.
            The last example can be achieved by smart offset. I think it is more difficult to just do the interior edges.
            So for now smart offset for multiple edges and split faces for single edges...
            • hdpvH Offline
              hdpv
              Hello Namelessone!
              Try my plugin S4u Frame.
              http://sketchucation.com/pluginstore?pln=s4u_frame
              Suforyou
              http://www.sketchupforyou.com
              • cottyC Offline
                cotty
                @Huynh: very nice plugin! Works great for this example.
                my SketchUp gallery
                • cottyC Offline
                  cotty
                  Quick example...
                  my SketchUp gallery
                    French version πŸ˜‰
                    Click image for Animation! πŸ€“
                    s4u_frame.zip
                      PS Seems Triangulated frames must be refined! πŸ˜‰
                        dtrarch
                        Hi All
                        s4u Frame and s4u Slice are just must have plugins.
                        Perfect for this use and ONE click to go. πŸ‘ πŸ‘ πŸ˜„ πŸ˜„
                        Thanks Vi
                        dtr
                        • hdpvH Offline
                          hdpv
                          Thank you!
                          @Pilou: convert lines to curve ,It'll work correct.
                          Suforyou
                            Convert line to curves
                            Very cool trick! πŸ‘ 😎 β˜€
                            • cottyC Offline
                              cotty
                              Can you explain the "trick" a bit more, please?
                              my SketchUp gallery
                                The trick! πŸ˜‰
                                And all will work fine! 😎
                                • cottyC Offline
                                  cotty
                                  And for my example (e.g. rectangle with diagonal)?
                                  my SketchUp gallery
                                    My original http://sketchucation.com/pluginstore?pln=Latticeizer
                                    Maybe not the best, but you judge...
                                    • pbacotP Offline
                                      S4U Frame worked for me (though I was confused trying to figure out the settings). But with this plugin loaded, SU crashes on relaunch--on my Mac.
                                      • cottyC Offline
                                        cotty
                                        πŸ‘
                                        It's hard to remember all your great plugins, isn't it?
                                        my SketchUp gallery
                                          @Cotty
                                          As a rectangle + diagonal = 2 triangles πŸ’­
                                          Select all segments and same trick! πŸ˜„
                                          But the result will be not so nearly almost perfect that the excellent Lattice-izer of TIG that I have used
                                          in this thread of anthology (2010) πŸ˜„
                                          You will find inside that some same results can be made with Windowizer by Rick Wilson, Street Generator by Thomthom, 1001bits etc...! πŸ’š
                                          • hdpvH Offline
                                            hdpv
                                            @Cotty
                                            Because you only select edges. In this case(rectangle + diagonal) ,first you need make face (Edges have faces).
                                            Suforyou
                                            • 2 / 3
