    Is there pluging for expanding/making face along line/edges?
    41 Posts 12 Posters 4.5k Views 12 Watching
      PS Seems Triangulated frames must be refined! πŸ˜‰
        dtrarch
        Hi All
        s4u Frame and s4u Slice are just must have plugins.
        Perfect for this use and ONE click to go. πŸ‘ πŸ‘ πŸ˜„ πŸ˜„
        Thanks Vi
        dtr
        • hdpvH Offline
          hdpv
          Thank you!
          @Pilou: convert lines to curve ,It'll work correct.
          Suforyou
          http://www.sketchupforyou.com
            Convert line to curves
            Very cool trick! πŸ‘ 😎 β˜€
            • cottyC Offline
              cotty
              Can you explain the "trick" a bit more, please?
              my SketchUp gallery
                The trick! πŸ˜‰
                And all will work fine! 😎
                • cottyC Offline
                  cotty
                  And for my example (e.g. rectangle with diagonal)?
                  my SketchUp gallery
                    My original http://sketchucation.com/pluginstore?pln=Latticeizer
                    Maybe not the best, but you judge...
                    • pbacotP Offline
                      S4U Frame worked for me (though I was confused trying to figure out the settings). But with this plugin loaded, SU crashes on relaunch--on my Mac.
                      • cottyC Offline
                        cotty
                        πŸ‘
                        It's hard to remember all your great plugins, isn't it?
                        my SketchUp gallery
                          @Cotty
                          As a rectangle + diagonal = 2 triangles πŸ’­
                          Select all segments and same trick! πŸ˜„
                          But the result will be not so nearly almost perfect that the excellent Lattice-izer of TIG that I have used
                          in this thread of anthology (2010) πŸ˜„
                          You will find inside that some same results can be made with Windowizer by Rick Wilson, Street Generator by Thomthom, 1001bits etc...! πŸ’š
                          • hdpvH Offline
                            hdpv
                            @Cotty
                            Because you only select edges. In this case(rectangle + diagonal) ,first you need make face (Edges have faces).
                            Suforyou
                              My 'Latticeizer' uses all faced-Edges in the preselected Group as the center-lines for its extrusions -
                              including the perimeter edges, so offset the main face inwards by half the extruded width before sub-dividing and erase the outer edges to move the assumed perimeter inwards, and then the over all size will be maintained when it's a lattice...
                              In its dialog you can choose different dimensions, materials and whether or not there are 'panes' to the lattice etc...
                              • 2 / 3
