    Layout won't save
    layout
    9 Posts 4 Posters 3.0k Views 4 Watching
    • zain01Z Offline
      zain01
      Hi can anyone tell me why Layout has started to show an error message saying i cant save a document with punctuation marks in the name? I have taken the punctuation marks out and it still wont save so basically i cant save anything. Thanks in advance.
        driven
        You can't normally use : in a filename on a mac, it's a path posix separator...
        Did you import the set of folders from a PC?
        I really can't make a folder named "Test:Folder" for example, but you have the one named SPYKER_2:06, which is possibly the cause for your issue...
        john
          slbaumgartner
          This appears to be a Layout-specific catch. From the command line, I can create a folder with a : in the name (though Finder displays it as a / afterward). Layout refuses to save a file to that folder. However, SketchUp quite happily saves to the folder. So it is in the Layout code, not a generic issue!
            driven
            @steve, I can't even make them in 'Finder', so it's not Layout specific for me...
            if I attempt to use : from a 'Save' dialog in SU, it shows a dash, not a colon I'm trying to enter...
            and as you found mkdir converts it to a slash...
              slbaumgartner
              John, your experience seems to differ from mine...I wonder why? Having a ":" in a folder name is a very bad idea, bound to cause problems, so I am interested mainly from a technical point of view.
              Using the terminal command line, I can mkdir a folder with a ":" in its name. The "ls" command shows it with a ":". So Mac OS itself can deal with a ":". But Finder displays it as a "/" even though ":" is not a path separator (foo:bar is a single folder, not two nested ones as foo/bar), and when I save a SU file to that folder, the save dialog also shows "/" (and SU successfully saves the file). The save dialog in Layout also shows it as "/", but when I try to save there, I get that popup with the message that I can't save to a folder with punctuation in its name. So, I conclude that this is due to how the various apps were programmed, not a fundamental aspect of Mac OS X.
                driven
                just dug this up...
                The only illegal character for file and folder names in Mac OS X is the colon ":"
                File and folder names are not permitted to begin with a dot "."
                File and folder names may be up to 255 characters in length
                how apps handle it obviously differs, for me SU changes it to a dash, LO rejects it with a message, Terminal changes it to an escaped colon, as seen if you drag the folder in i.e. /private/tmp/new:tmp...
                Bottomline for the OP is in the quote The only illegal character for file and folder names in Mac OS X is the colon ":"
                john
                • zain01Z Offline
                  zain01
                  Thanks all for the info
                  I have been saving files in Layout with names like for example
                  22.06.15_MBU_01
                  for the past 2 years with no issues
                  All of a sudden it wouldn't save it to the target folder so i saved it to the desktop and then moved it afterwards.
                  And now i am having to re link the SU file every time i open the relevant Layout file.
                  Can anyone tell me why i am having this re linking problem?
                  The amount of time i am wasting navigating to the file to re link is ingratiating.
                  Also dangerous if subtle changes in the model are not reflected in Layout as the joinery i am drafting is constantly changing.
                  Regards
                    So evidently you didn't get this from the last post by John?
                      driven
                      to clarify what I was pointing out...
                      any filename includes the path, and yours contains ../SPYKER_2:06/.., with the 2 and the 0 separated by a colon...
                      then Steve and I chat about how some apps cope with what is considered by Apple the only 'illegal' character.
                      Change the colon and all should work...
                      john
