    Automatically splitting overlapped shape and removing part
    15 Posts 4 Posters 1.3k Views 4 Watching
    • H
      hanl000
      Hello, I'm looking for tools and ideas which can express like B from A(see a below picture). Of course, I can make it with a basic tool in Sketchup, but would like to split and remove shapes together in once.
      http://postfiles7.naver.net/20150526_278/hanl000_1432643023170dXzj5_PNG/����_����.png?type=w3
      • D
        driven
        your image won't load for me...
        try uploading from your desktop...
        • H
          hanl000
          I attached a file again. please see it again
            Your profile indicates you have the pro version of SU2014. Use the Subtract tool in the solid tools set to subtract the sphere's from the box. Remember to make each a component or group prior to running Subtract.
            • H
              hanl000
              Thank you for your kind reply,,,But I wanna get a tool which can subtract spheres in once. In the attached picture, I have to subtract spheres twice. My works mainly require overlapped shapes should be cut by subtraction. I'd like to save clicks
                If three or four clicks is too much work for you, maybe you should hire someone else to do it.
                • D
                  driven
                  john
                  • pbacotP
                    driven, that's three clicks.
                      Well, you could call the Subtract tool with a keyboard shortcut. And if there was a plugin you'd have to either click on a toolbar button, call it from a menu (an additional click) or use a keyboard shortcut. Seems like the native option is as efficient if not more so than a plugin could be.
                      • D
                        driven
                        ok, how about one 'click'...presto...
                        • pbacotP
                          You make it look easy.
                          • H
                            hanl000
                            @driven said:
                            ok, how about one 'click'...[attachment=1:1jw3wdk9]<!-- ia1 -->subtract.gif<!-- ia1 -->[/attachment:1jw3wdk9]
                            It looks a good way, but I wanna try 'split' and 'deletion' in once. 'Subtract' erases even surface of hexahedron. 'Split' leaves surface, only erases shapes out of the hexahedron. In the picture, Left one is a result of 'subtract' and right one is a result of split. I'm looking for ideas can make a result of right one after only one-two steps
                            • pbacotP
                              Looks like you are getting two results on the right, one including z-flashing? I note that if the groups are colored instead of the faces themselves, results in split colors can be erratic.
                              • H
                                hanl000
                                My main work is calculating volume for hexahedron, but original shape should be retained. In the example, I need only four clicking to remove sphere. In my work, I have to repeat and repeat it. Really boring. I want to save time by making a tool which splits and removes sphere in once
                                • D
                                  driven
                                  post a before and an after model. it's really hard to envision what you mean...
                                  john
