    Automatically splitting overlapped shape and removing part
    15 Posts 4 Posters 1.3k Views 4 Watching
      If three or four clicks is too much work for you, maybe you should hire someone else to do it.
        driven
        • pbacotP
          driven, that's three clicks.
            Well, you could call the Subtract tool with a keyboard shortcut. And if there was a plugin you'd have to either click on a toolbar button, call it from a menu (an additional click) or use a keyboard shortcut. Seems like the native option is as efficient if not more so than a plugin could be.
              driven
              ok, how about one 'click'...presto...
              • pbacotP
                You make it look easy.
                • H
                  hanl000
                  @driven said:
                  ok, how about one 'click'...[attachment=1:1jw3wdk9]<!-- ia1 -->subtract.gif<!-- ia1 -->[/attachment:1jw3wdk9]
                  It looks a good way, but I wanna try 'split' and 'deletion' in once. 'Subtract' erases even surface of hexahedron. 'Split' leaves surface, only erases shapes out of the hexahedron. In the picture, Left one is a result of 'subtract' and right one is a result of split. I'm looking for ideas can make a result of right one after only one-two steps
                  • pbacotP
                    Looks like you are getting two results on the right, one including z-flashing? I note that if the groups are colored instead of the faces themselves, results in split colors can be erratic.
                    • H
                      hanl000
                      My main work is calculating volume for hexahedron, but original shape should be retained. In the example, I need only four clicking to remove sphere. In my work, I have to repeat and repeat it. Really boring. I want to save time by making a tool which splits and removes sphere in once
                        driven
                        post a before and an after model. it's really hard to envision what you mean...
