[Plugin] Guides Proxy
Tools to save Guide-Points and Guide-Lines as a Guides_Proxy Group, and restore them later etc...
See Overview...
http://sketchucation.com/pluginstore?pln=TIG_GuidesProxy -
Thank you, a nice workaround to prevent the deletion of some guidelines and construction points...
hey TIG thank you for this...
youยดre awsome -
Can this not add the Proxy Layer on right-click if I've a cLine selected but no intention of activating Guide to Proxy?
It is adding the Layer on every right click....
It's a simple fix.
I'll issue an update later today... -
Here's v1.1 http://sketchucation.com/pluginstore?pln=TIG_GuidesProxy The new layer is now made only if the tool is actually used.
it is a nice idea
to save like the pattern of a model made of components, being able to remove it for distribution, and restore it for internal purposei tried, but the cpoints embedded in components are not saved by the the plugin
The guide-lines/points need to be selected.
So you need to edit the 'container' - group or component.
Then you can save the proxy inside the container itself.
To save a proxy outside of the container could lead to all sorts of confusion.
If you moved the component in the model its disconnected cpoints would not move with it...
With your input, this post could be even better ๐
Register LoginAdvertisement
