    [Plugin] Guides Proxy
    9 Posts 5 Posters 1.4k Views 5 Watching
      Tools to save Guide-Points and Guide-Lines as a Guides_Proxy Group, and restore them later etc...
      See Overview...
      http://sketchucation.com/pluginstore?pln=TIG_GuidesProxy
      • cottyC Offline
        cotty
        Thank you, a nice workaround to prevent the deletion of some guidelines and construction points...
        my SketchUp gallery
        • deaneauD Offline
          deaneau
          hey TIG thank you for this... 👍 👍 👍 👍 👍 you´re awsome
            Can this not add the Proxy Layer on right-click if I've a cLine selected but no intention of activating Guide to Proxy?
              It is adding the Layer on every right click....
                It's a simple fix.
                I'll issue an update later today...
                  Here's v1.1 http://sketchucation.com/pluginstore?pln=TIG_GuidesProxy The new layer is now made only if the tool is actually used.
                    glro
                    it is a nice idea
                    to save like the pattern of a model made of components, being able to remove it for distribution, and restore it for internal purpose
                    i tried, but the cpoints embedded in components are not saved by the the plugin
                      The guide-lines/points need to be selected.
                      So you need to edit the 'container' - group or component.
                      Then you can save the proxy inside the container itself.
                      To save a proxy outside of the container could lead to all sorts of confusion.
                      If you moved the component in the model its disconnected cpoints would not move with it...
