    Speed modeling a Tufted Cushion
    13 Posts 6 Posters 6.7k Views 6 Watching
    • Rich O BrienR Online
      Not so much a tutorial...but some fun with Thomthom new SubD
        Comfortable! 😎
        • JQLJ Offline
          JQL
          Looking good and I love the way you present stuff...
          The vΓ­deo is moving super fast so it seems everything is smooth, is it?
          Some questions here just to know that everything is in the right place: couldn't you have used the select loops on quad face tools for those line selections? Or maybe whaat's SketchUV path select tool? And wouldn't a component for the buttons work faster? Or isn't it possible use them with SubD somehow?
          Seems it will be a great addition to the arsenal!
          www.casca.pt
          Visit us on facebook!
            Yes, it is smooth at realtime too.
            No, my topology meant that loop select ended up going to the button pole.
            not installed
            i rarely use components when modeling. afterwards i'd revisit it but only if the file was intended for someone who needed it as light as possible.
            of course....anything is possible
            • HieruH Offline
              Hieru
              Nice 'blink and you'll miss it' SubD preview. The Vertex Tools workflow was however really useful πŸ‘
              www.davidhier.co.uk
                I know i set up speed control to 10x the capture speed and 10mins of model time became 43secs....
                • pbacotP Offline
                  Nice and you play piano so well too.
                  • cottyC Offline
                    cotty
                    @rich o brien said:
                    not installed
                    You should...
                    my SketchUp gallery
                      I had it. I just stopped using it.
                      When that happens I tend to remove extensions. Especially ones that no longer see development.
                      • JQLJ Offline
                        JQL
                        I do understand, but what else could he develop in his path select tool? It's perfect! Or are you talking about the UV part of SketchUV? Couldn't you use it with blender?
                        www.casca.pt
                          Path Select works fine but it is also now in Profile Builder 2(or a variant of it).
                          QuadFace Tools offers all the selection options i need at the moment. Also I use TGI3D and that has a very powerful set of selection options.
                          SketchUV often failed to successfully import UVs. It left many faces which strangely skewed tris for no reason other than it fails.
                          SketchUV is an awesome tool and a great asset to have. But for me I just think ThruPaint or exporting to Collada is a cleaner and reliable workflow. For now anyway.
                          • JQLJ Offline
                            JQL
                            You export for collada and then back at sketchup or you export to collada to get the work going at say... blender and stop SU from there?
                            www.casca.pt
                              I only come back to SketchUp if the final output I need to deliver is .skp.
                              I tend to use other tools to convert to skp.
