    Sketchup quits (bug splat) when using cmd-C
    9 Posts 3 Posters 3.3k Views 3 Watching
    • emnE
      emn
      I'm experiencing bug splats when tryiny to copy drawn items to another drawing.
      Sketchup pro 2015
      Vray for sketchup
      Mac OS Maverick
      File I'm trying to copy is a 16 MB file. Already checked the file for problems en purge unused.
      Whenever I select the items I want to copy and use the cmd-C key, Sketchup quits and reports a bug splat.
      If I select fewer items and use the same procedure, the bug splat does not occure.
      Any solutions?
      • D
        driven
        Does it happen with 'Vray' disabled?
        what other plugins are you running?
        john
        • emnE
          emn
          Other plugins installed:
          Mirror
          Roundcorner
          I'm not sure how to disable Vray. Suggestions?
          I do however have another problem with vray: When I have two windows (two files) open under sketchup, I can only see one materials list in the material browser of vray.
          In other words: When I'm working in one file, I see the materials of the other file.
          • D
            driven
            @emn said:
            ...I'm not sure how to disable Vray. Suggestions?
            I removed Vray many years ago so I'm not sure, is there an extension registered in 'SU [menu]' >> 'Preferences' >> 'Extensions'?
            ...In other words: When I'm working in one file, I see the materials of the other file.
            I believe that window is always per model, so if you close it before switching, does it show the correct model when re-opened?
            john
            • emnE
              emn
              OK. I found the option to disable Vray. As you said: under preferences.
              Disabling vray does nog solve the problem. Sketchup still crashes when useing Cmd-C.
              The other issues with the materials: No, when I close the other window, the materials of the closed drawing is still showing.
              • S
                slbaumgartner
                Did you attach descriptive and identifying info to the Bug Splat reports? If so, someone from Trimble should notice and respond.
                • emnE
                  emn
                  Yes I did. Thank's for your reply!
                  • D
                    driven
                    another approach may be...
                    make a copy using 'Finder', open the copy, delete unwanted items, purge and save...
                    john
                    • emnE
                      emn
                      That's what I've been doing. I'ts quite an effort though to do that with every item you want to use.....
                      Thanks for your reply though.
