Sketchup quits (bug splat) when using cmd-C
I'm experiencing bug splats when tryiny to copy drawn items to another drawing.
Sketchup pro 2015
Vray for sketchup
Mac OS MaverickFile I'm trying to copy is a 16 MB file. Already checked the file for problems en purge unused.
Whenever I select the items I want to copy and use the cmd-C key, Sketchup quits and reports a bug splat.
If I select fewer items and use the same procedure, the bug splat does not occure.Any solutions?
Does it happen with 'Vray' disabled?
what other plugins are you running?
john -
Other plugins installed:
Mirror
RoundcornerI'm not sure how to disable Vray. Suggestions?
I do however have another problem with vray: When I have two windows (two files) open under sketchup, I can only see one materials list in the material browser of vray.
In other words: When I'm working in one file, I see the materials of the other file. -
@emn said:
...I'm not sure how to disable Vray. Suggestions?
I removed Vray many years ago so I'm not sure, is there an extension registered in 'SU [menu]' >> 'Preferences' >> 'Extensions'?
...In other words: When I'm working in one file, I see the materials of the other file.
I believe that window is always per model, so if you close it before switching, does it show the correct model when re-opened?
john -
OK. I found the option to disable Vray. As you said: under preferences.
Disabling vray does nog solve the problem. Sketchup still crashes when useing Cmd-C.
The other issues with the materials: No, when I close the other window, the materials of the closed drawing is still showing. -
Did you attach descriptive and identifying info to the Bug Splat reports? If so, someone from Trimble should notice and respond.
Yes I did. Thank's for your reply!
another approach may be...
make a copy using 'Finder', open the copy, delete unwanted items, purge and save...
That's what I've been doing. I'ts quite an effort though to do that with every item you want to use.....
Thanks for your reply though.
