    Sketchup quits (bug splat) when using cmd-C
    9 Posts 3 Posters 3.2k Views 3 Watching
    • emnE Offline
      emn
      I'm experiencing bug splats when tryiny to copy drawn items to another drawing.
      Sketchup pro 2015
      Vray for sketchup
      Mac OS Maverick
      File I'm trying to copy is a 16 MB file. Already checked the file for problems en purge unused.
      Whenever I select the items I want to copy and use the cmd-C key, Sketchup quits and reports a bug splat.
      If I select fewer items and use the same procedure, the bug splat does not occure.
      Any solutions?
        driven
        Does it happen with 'Vray' disabled?
        what other plugins are you running?
        • emnE Offline
          emn
          Other plugins installed:
          Mirror
          Roundcorner
          I'm not sure how to disable Vray. Suggestions?
          I do however have another problem with vray: When I have two windows (two files) open under sketchup, I can only see one materials list in the material browser of vray.
          In other words: When I'm working in one file, I see the materials of the other file.
            driven
            @emn said:
            ...I'm not sure how to disable Vray. Suggestions?
            I removed Vray many years ago so I'm not sure, is there an extension registered in 'SU [menu]' >> 'Preferences' >> 'Extensions'?
            ...In other words: When I'm working in one file, I see the materials of the other file.
            I believe that window is always per model, so if you close it before switching, does it show the correct model when re-opened?
            • emnE Offline
              emn
              OK. I found the option to disable Vray. As you said: under preferences.
              Disabling vray does nog solve the problem. Sketchup still crashes when useing Cmd-C.
              The other issues with the materials: No, when I close the other window, the materials of the closed drawing is still showing.
                slbaumgartner
                Did you attach descriptive and identifying info to the Bug Splat reports? If so, someone from Trimble should notice and respond.
                • emnE Offline
                  emn
                  Yes I did. Thank's for your reply!
                    driven
                    another approach may be...
                    make a copy using 'Finder', open the copy, delete unwanted items, purge and save...
                    • emnE Offline
                      emn
                      That's what I've been doing. I'ts quite an effort though to do that with every item you want to use.....
                      Thanks for your reply though.
