    How to Make a Bowl of Random Components
    29 Posts 6 Posters 2.4k Views 6 Watching
    • Mistro11M Offline
      Mistro11
      Show collision is still active. I just got a bugsplat halfway through the animation after multiplying the cereal. What kind of optimizations should I be aware of? I'm thinking my cereal have too many faces. Yeah, I wish I could use this in 2015 64bit.
      i7-4930k @3.4/3.7GHz, 32Gb RAM, NVidia GTX 980Ti 6Gb, Windows 7 Pro 64bit
      Structural Integrity is Not Just Physical...It's in the Design and Purpose
      • cottyC Offline
        cotty
        For my animation, I only have deactivated the show collision setting without changing your geometry of the cereal.
        my SketchUp gallery
        • Mistro11M Offline
          Mistro11
          I figured out why my scene was so heavy. I didn't make the cereal into a component. After making it into a component, it runs much smoother. Thanks again.
            i think blender will serve you better in this instance. without suffering from crashes
            click image to view gif...
            set the bowl as a collision object
            set a plane to emit your cereal shape
            after simulating you can export to SU....
            • Mistro11M Offline
              Mistro11
              Thanks Rich. Yeah, Blender is my other workhorse. I do want to make my cereal with more complex shapes without worrying about crashes so I will try that next.
                of course! πŸ˜‰
                • Mistro11M Offline
                  Mistro11
                  One more question...Is it possible to tweak the scene after pausing the simulation? The cereal fell in a perfect way but I want to tweak the materials and export the scene to Thea Studio. Any attempt to select anything outside SP tools results in a reset of the simulation.
                    At the "pause" Save your file! πŸ€“
                    So if you reload it as a new session of SU, you can change anything before relaunch a new simulation! πŸ˜‰
                    • Mistro11M Offline
                      Mistro11
                      Thank you Pilou! That works although I cannot press file>save when in pause. I Ctrl+S but was not sure if it worked. It sat there long enough to give me an autosave so I wasn't worried. When I restarted, it launched normally with my bowl of cereal the way I left it. πŸ˜„
                      • 2 / 2
