    How do I convert back a vray proxy to polygons?
    renderpluginsextensions
    7 Posts 6 Posters 13.7k Views 6 Watching
      cuttingedge
      Hi Guys,
      I have some really good models that are in vray proxy form and I want to like tweak it a bit, change materials and other things.. How do I convert it to polygons without losing materials and UV info?
      Edd
        dkendig
        Not possible
        Devin Kendig
        Developer
          cuttingedge
          @dkendig said:
          Not possible
          oh...i hope one day it will be possible. some components from 3dWH are in form of proxies. Thought proxies are jst compressed infos that can be decompressed. why, that's one way to protect your model from getting altered...πŸ˜„
            rohangandhi19
            its so Simple.
            1.Select the proxy in model
            2. Right click & select Reload from the new window
            3. after click on reload you must have to select the original skp file of that element & click ok.
            4. Boooommmm your proxy is replaced as a original model.
              davidgafas
              @rohangandhi19 said:
              its so Simple.
              YOU ARE THE BEST!!!! I THOUGHT I WAS LOST
                lovellmarc @davidgafas
                @davidgafas What if theres no orignal file to load? so its impossible, right?
                panixiaP 1 Reply Last reply Reply Quote 0
                • panixiaP Online
                  panixia @lovellmarc
                  @lovellmarc not sure about the SketchUp/Rhino version, but in Vray for 3dsMax there's an useful option in the proxy settings window called "extract mesh" (or something like that), which does exactly what you are asking for. Did you check if there's a similar option in the SU version?
