    [PLUGIN] Flowify v1.1.0 (updated 150327)
    126 Posts 57 Posters 210.0k Views 57 Watching
    • G Offline
      Gama_Pro
      hi!!! i love this plugin, but i had a problem. It doesnt running in SK2016. Where can i get this plugin for SK2016?
      thks!!
        beecee660
        Hello,
        I am having problems shaping this perforated disc into the target dome. Keep getting this INPUT ERROR, screen grab attached.
        Can anyone help? Are domes not possible? I gave it a base square as I read flowify only works with quads.
        I successfully did it with a different shape yesterday I copied off a video tutorial.
        I would appreciate any advice.
        Many thanks.
          Why not publish your SKP file problem?
          It's difficult to say something about an image! πŸ˜„
          Maybe there are some overlapings...but without the file...
          • cottyC Offline
            cotty
            You can use the quadfacetools (Thomthom) to control the quads...
            my SketchUp gallery
            • cottyC Offline
              cotty
              Another example model...
              flowify_cotty_07.skp
              my SketchUp gallery
              • cottyC Offline
                cotty
                Another example...
                my SketchUp gallery
                • cottyC Offline
                  cotty
                  And another one...
                  my SketchUp gallery
                    Funny use results! 😎
                    • cottyC Offline
                      cotty
                      And... another one:
                      my SketchUp gallery
                      • panixiaP Offline
                        panixia
                        i love the last one, cotty!
                        • cottyC Offline
                          cotty
                          my SketchUp gallery
                          • panixiaP Offline
                            panixia
                            i shared this mini-tutorial in the sub-d section, but i would like to share the link here to, because i also used flowify in the modeling process of this lamp..
                            http://sketchucation.com/forums/viewtopic.php?f=397%26amp;t=66269
                            • cottyC Offline
                              cotty
                              A XMAS example...
                              my SketchUp gallery
                                @Cotty
                                Happy new year! 😎
                                Seems you can use in this last case above only FredoScale! πŸ˜‰
                                Use Twice the radial Bending!
                                  shahrishabh126
                                  it is showing error.please help Sir.
                                  • G Offline
                                    gnome_mo
                                    Do I need to make quad from regular sketchup triangulated model? If so, how?
                                    I don't get any errors, just my projection plane gets divided and extruded for the width of my group, but it never gets projected on a needed surface.
                                    • V Offline
                                      Vizan
                                      Hello! How can I apply top geometry to bottom using your plugin?
                                        It's not an "Apply" it's a "Deformation" πŸ˜‰
                                        So maybe the result can be that you want...
                                        https://sketchucation.com/forums/download/file.php?id=129748
                                          bhuta_n
                                          I cant use flowify in sketchup 8. Is is compatibele with SK 8?
                                          • N Offline
                                            Nan Htet Htet Aye Mon
                                            Hello...
                                            I am using the sketchup 2020 and cannot use it in mine.
                                            Is it not support for 2020 version yet?
                                            • 6
                                            • 7
                                            • 4 / 7
