    [PLUGIN] Flowify v1.1.0 (updated 150327)
    126 Posts 57 Posters 220.7k Views 57 Watching
      RueM
      I found where it could came from. I did an other operation before and made a grid and the plane surface then. I didn't removed that grid, and it might not feet to the new operation (so flowify might calcules with false beginning and ending geometry).
      I made an other plane rectangular with any grid and it worked perfectly.
      We can still have the model to see what crasy results it mades.
      Thanks a lot
      issue and solution
        Align Target surface by the middle from the Source surface avoid generally some problem for the 2 lines! πŸ€“
        • cottyC
          cotty
          Some spiral examples...
          flowify_cotty_06.skp
          my SketchUp gallery
          • C
            capseyb
            Thanks for this plugin.
            I've been having a lot of trouble with errors with grid parsing, even with simple geometry. Would anyone be able to quickly diagnose what is wrong with the attached model?
            Thanks again,
            Brian
            bend4.skp
            • cottyC
              cotty
              There were little edges or errors in your quad mesh, after repairing them, it worked like a charm...
              bend4_cotty.skp
              my SketchUp gallery
              • C
                CAUL
                Thanks cotty! I was just trying to find the error.
                • yanrothwellY
                  yanrothwell
                  I have a curved roof to make with some simple wedge shaped shingles. Each time I try to use Flowify to bed the shingles onto the 'roof' I get a strange result making the result, un-flowified and huge.
                  I am puzzled and presume I must be doing something wrong. I explode all the components and groups of the shingles so it is only what I believe to be raw geometry, then group it place it on the target quad mesh, click on Flowify.
                  Any ideas where I've messed up? (skp attached).
                  I'm using SU pro 2015
                  [Edit] Realised it's something to do with multiple objects, but I this seems to work in the Demo Video?
                  parts for Flowify shingles.skp
                  http://www.ianrothwell.co.uk
                  • C
                    CAUL
                    Thank you for the file! It's a bug in Flowify and it seems to be in the intersection part of the extension, so you can still use**'Flowify without cut'**. Maybe that is enough?
                    Nevertheless, I'm looking into it.
                      Volume to project can't be group of groups!
                      So explode all many time and re-group !
                      Surface Start must be a surface and not a volume!
                      But there is also something wrong in your first original shingle!
                      So redraw it!
                      Another thing : center your target surface for avoid over crossing of the 2 lines toward the extremities!
                      Edit : seems i move over a bug! πŸ’š
                      • G
                        Gama_Pro
                        hi!!! i love this plugin, but i had a problem. It doesnt running in SK2016. Where can i get this plugin for SK2016?
                        thks!!
                        • B
                          beecee660
                          Hello,
                          I am having problems shaping this perforated disc into the target dome. Keep getting this INPUT ERROR, screen grab attached.
                          Can anyone help? Are domes not possible? I gave it a base square as I read flowify only works with quads.
                          I successfully did it with a different shape yesterday I copied off a video tutorial.
                          I would appreciate any advice.
                          Many thanks.
                            Why not publish your SKP file problem?
                            It's difficult to say something about an image! πŸ˜„
                            Maybe there are some overlapings...but without the file...
                            • cottyC
                              cotty
                              You can use the quadfacetools (Thomthom) to control the quads...
                              my SketchUp gallery
                              • cottyC
                                cotty
                                Another example model...
                                flowify_cotty_07.skp
                                my SketchUp gallery
                                • cottyC
                                  cotty
                                  Another example...
                                  my SketchUp gallery
                                  • cottyC
                                    cotty
                                    And another one...
                                    my SketchUp gallery
                                      Funny use results! 😎
                                      • cottyC
                                        cotty
                                        And... another one:
                                        my SketchUp gallery
                                        • panixiaP
                                          panixia
                                          i love the last one, cotty!
                                          • cottyC
                                            cotty
                                            my SketchUp gallery
                                            • 4 / 7
