    Sophie with ngPlant
    15 Posts 6 Posters 3.7k Views 6 Watching
    • david57D Offline
      david57
      Tree and bushes made with ngPlant.
      I was curious to know if i could import an ngPlant bush into Sketch-up
      and did it but Sketch-up file is to big. Its a 20MB file and not a good
      idea. Managed to export the Sophie and the bush.
      The tree looks like it got a flat top hair cut.
      Well, nobody is perfect, ha ha.
      • jujuJ Offline
        juju
        try to use proxy components, it should help (depending on your workflow)
        • david57D Offline
          david57
          Ok juju,
          Thanks.
          • david57D Offline
            david57
            Trying to fix the big tree. Maybe just get rid of it.
            • pbacotP Offline
              Nice tree. Leaves are large but the shape is like the oaks around here and often hard to find something like that when you need a big oak tree.
              • olisheaO Offline
                olishea
                If you want to export to SU, use the collada exporter πŸ˜‰ I love NG Plant. There are some good video tutorials by Jim Allen on the NG website too.
                There are ways of reducing the file size without necessarily impacting the way the tree looks. Reduce the branch resolution for example. 8 sides for the main trunk, then 4 sides for intermediate branches and then 3 sides for twigs. It's barely noticeable.
                oli
                • david57D Offline
                  david57
                  olishea,
                  Thanks for website and advice.
                  I found a beautiful tree at the ngPlant wiki.
                  The file is called JA_Sorbus_intermedia_Whitebeam.nga.
                  Needs to be converted to a ngp file.
                  Here's the what it looks like.
                  • david57D Offline
                    david57
                    Working with some background trees.
                    • david57D Offline
                      david57
                      I found a nice Architectural Scene on the net.
                      Im trying to imitate one of the trees.
                      I dont know if i will do the whole scene.
                      Looks hard.
                      It can be found here:
                      https://www.flickr.com/photos/dickclarkarchitecture/3269456609/
                      • david57D Offline
                        david57
                        A quick test render.
                        Concrete portion was made and textured with sketch-up.
                        Trees from ngPlant.
                        The trench was sculpted with blender.
                        Need to place weeds inside the trench.
                          Not sure if it is your colour profile or mine but there's a distinctive purple hue to your image.
                          The concrete and bark looks particularly purple in appearance.
                          Nice results nonetheless. Well done.
                          • hellnbakH Offline
                            hellnbak
                            Yeah, looks purple to me too. Maybe lavender
                            • david57D Offline
                              david57
                              Yes, it looks violet. Its the hdr that is making the materials look strange.
                              Looking for the best hdr and every time i have to adjust my materials for it.
                              • david57D Offline
                                david57
                                Here is another render. Leaf material on the trees need to be adjusted again.
                                • david57D Offline
                                  david57
                                  Had to fix the right hand-side tree.
