Sophie with ngPlant
Tree and bushes made with ngPlant.
I was curious to know if i could import an ngPlant bush into Sketch-up
and did it but Sketch-up file is to big. Its a 20MB file and not a good
idea. Managed to export the Sophie and the bush.
The tree looks like it got a flat top hair cut.
Well, nobody is perfect, ha ha.
try to use proxy components, it should help (depending on your workflow)
Ok juju,
Thanks. -
Trying to fix the big tree. Maybe just get rid of it.
Nice tree. Leaves are large but the shape is like the oaks around here and often hard to find something like that when you need a big oak tree.
If you want to export to SU, use the collada exporter
I love NG Plant. There are some good video tutorials by Jim Allen on the NG website too.
There are ways of reducing the file size without necessarily impacting the way the tree looks. Reduce the branch resolution for example. 8 sides for the main trunk, then 4 sides for intermediate branches and then 3 sides for twigs. It's barely noticeable.
olishea,
Thanks for website and advice.
I found a beautiful tree at the ngPlant wiki.
The file is called JA_Sorbus_intermedia_Whitebeam.nga.
Needs to be converted to a ngp file.Here's the what it looks like.
Working with some background trees.
I found a nice Architectural Scene on the net.
Im trying to imitate one of the trees.
I dont know if i will do the whole scene.
Looks hard.
It can be found here:mount bonnell modern architecture
Modern 5-story home nestled into the mount bonnell hills Project designed by Dick Clark Architecture of Austin, Texas
Flickr (www.flickr.com)
A quick test render.
Concrete portion was made and textured with sketch-up.
Trees from ngPlant.
The trench was sculpted with blender.
Need to place weeds inside the trench.
Not sure if it is your colour profile or mine but there's a distinctive purple hue to your image.
The concrete and bark looks particularly purple in appearance.
Nice results nonetheless. Well done.
Yeah, looks purple to me too. Maybe lavender
Yes, it looks violet. Its the hdr that is making the materials look strange.
Looking for the best hdr and every time i have to adjust my materials for it. -
Here is another render. Leaf material on the trees need to be adjusted again.
Had to fix the right hand-side tree.
