    Vray Material preview
    renderpluginsextensions
    8 Posts 6 Posters 3.5k Views 6 Watching
    • Y Offline
      yamh
      i dont know why when i import a vismat to sketchup, it looks gray in the model.
      http://i58.tinypic.com/2rdkftg.jpg
      http://i58.tinypic.com/fo0opc.jpg
      for example here i imported a wood floor material, but it looks gray... anyone??
      • chonC Offline
        chon
        Hello,
        as usual, which versions of SU and Vray do you use and on which web site did you download your material ? It is known that old materials downloaded from web are out to date and not compatible with recent versions of SU and Vray.
        SU2019 pro 19.3.253 + VRay 4.00.02 (Next) on Win10-64Bits
        • Y Offline
          yamh
          ok, thaks, i think thats the problem
            callinas
            Hi, some materials in vismat file don't have real texture but a different color. Only when rendering appears real texture
            • Y Offline
              yamh
              where can i download updated vismat?
              • Lampe au Néon Pelle à TarteL Offline
                Hi there !
                I had the same problem not long ago and I applied the following solution :
                1-when you download a vismat, you are provided with a folder containing several files.
                Usually the vismat itself, a bump file, a displacement file, AND a diffuse file.
                2-When your vismat is imported, select it with the eyedropper tool of the Material window in sketchup. Then in the Vray material Editor, in the "diffuse" section, click on the blue M between "color" and "transparency".
                3-In the Vray texture Editor, select TexBitmap in the list right Under the preview window.
                4-At the top of the window you're in, fill the "file" field by browsing and selecting the diffuse file that came with your downloaded vismat folder. It is a jpeg that usually has either a D or a "Diffuse" in its name.If it's already selected before browsing, act as if it was not, and select it + ok.
                5-Click ok and look at your material in your model now.
                Now it appears as such, and not as a plain meaningless color.
                Note that now, you can scale it like any sketchup material in the Material window of sketchup.
                From a beginner to another, my solution might not be so academic, but it worked for me. If it does for you, I'll be glad, since very simple questions for beginners generate very few interrest/answer in this forum. Unfortunately.
                B good and tell me about it.
                • I Offline
                  isacm88
                  Hey!! Thanks!! Lampe au Néon Pelle à Tarte... man you rocks! it works! 😄 😄 😄
                  • N Offline
                    NeloNath
                    @lampe au néon pelle à tarte said:
                    Hi there !
                    Amazing! Thank you very much.
