    V-Ray not rendering - check ruby console for errors
    renderpluginsextensions
    3 Posts 2 Posters 5.6k Views 2 Watching
      JBBere
      I just downloaded V-ray and keep getting an error message when I try and Render. It tells me to check the ruby console for errors and I see this:
      "==== V-Ray for SketchUp =====
      undefined method /' for nil:NilClass + ["C:/ProgramData/ASGVIS/VfS/Ruby/VfSExport.rb:127:in push_vert'", "C:/ProgramData/ASGVIS/VfS/Ruby/VfSExport.rb:2868:in block in process_polymesh'", "C:/ProgramData/ASGVIS/VfS/Ruby/VfSExport.rb:2867:in each'", "C:/ProgramData/ASGVIS/VfS/Ruby/VfSExport.rb:2867:in process_polymesh'", "C:/ProgramData/ASGVIS/VfS/Ruby/VfSExport.rb:2814:in process_face'", "C:/ProgramData/ASGVIS/VfS/Ruby/VfSExport.rb:2397:in block in process_entities'", "C:/ProgramData/ASGVIS/VfS/Ruby/VfSExport.rb:2397:in each'", "C:/ProgramData/ASGVIS/VfS/Ruby/VfSExport.rb:2397:in grep'", "C:/ProgramData/ASGVIS/VfS/Ruby/VfSExport.rb:2397:in process_entities'", "C:/ProgramData/ASGVIS/VfS/Ruby/VfSExport.rb:2541:in process_compdef'", "C:/ProgramData/ASGVIS/VfS/Ruby/VfSExport.rb:2480:in block in process_compdefs'", "C:/ProgramData/ASGVIS/VfS/Ruby/VfSExport.rb:2478:in each'", "C:/ProgramData/ASGVIS/VfS/Ruby/VfSExport.rb:2478:in process_compdefs'", "C:/ProgramData/ASGVIS/VfS/Ruby/VfSExport.rb:2053:in process_doc'", "C:/ProgramData/ASGVIS/VfS/Ruby/VfSExport.rb:1976:in start_render'", "C:/ProgramData/ASGVIS/VfS/Ruby/R2PCallbacks.rb:538:in start_render_cb'", "C:/ProgramData/ASGVIS/VfS/Ruby/VfSExport.rb:1931:in direct_send'", "C:/ProgramData/ASGVIS/VfS/Ruby/VfSExport.rb:1931:in render'", "C:/ProgramData/ASGVIS/VfS/Ruby/R2P.rb:1470:in launch_vray_render'", "C:/ProgramData/ASGVIS/VfS/Ruby/R2PToolbar.rb:30:in block in <module:VRayForSketchUp>'", "SketchUp:1:in call'"]
      Scene fully processed in 0.042 seconds
      Any ideas? Could this be another plugin clashing with Vfs? The same error happens for cleanup 3.
        V-ray support guys might have seen this post, but for certainty I suggest you also get in touch with their support directly, and pass on the error-message and the SKP.
        The error-message is quite clear what is failing in the .rb file - even gives the line numbers !
        This kind of error could be trapped with a simple begin;...do_code..;rescue;...do_something_else...;end block of code...
          JBBere
          Oh I'm using sketchup 2015 on windows.
