    Need help with grainy render
    renderpluginsextensions
    4 Posts 3 Posters 1.3k Views 3 Watching
      slawomir
      Hello
      I need some help for my render, the image is grainy I tried adding more subdivides, inreasing image sampler, threshold, subdivide ligth cache, but the image still grainy I hope You can help me. I attached the render and the vray settings.
      render
      settings
      settings
      settings
      settings
      • V Offline
        valerostudio
        If you are using a dome light, up the subdivs on that. Grain can be controlled using suddivs. I would look into watching the Grant Warwick videos, which are V-Ray for Max but the core principles will really be eye opening for you. I learned a lot about controlling noise this way.
        http://masteringcgi.com.au/
        • TedVitale_CGT Offline
          TedVitale_CG
          Your settings are all over the place. Also, you're using an outdated beta of V-Ray for Sketchup that shouldn't even work anymore. I recommend you upgrade to V-Ray 2.0 and use the presets we provide.
          Ted Vitale
          Owner | Creative Director
          http://www.voxl.vision
            slawomir
            Ok, thanks I changed the image sampler from adaptative dmc to fixed rate and it works.
