    [Plugin] Add Icons [for all SU files on mac]
    47 Posts 8 Posters 13.4k Views 8 Watching
      driven
      if you want to change the red to Finder off white, copy/paste this code into 'Ruby Console' and hit Return...
      it should work without needing a restart of SU...
      filename = Sketchup.find_support_file("jcb_Add_Icon/Add_icon_logic.rb", 'Plugins')
      text = File.read(filename)
      content = text.gsub(/ FF0000 /, " e8e9e8 ")
      File.open(filename, "w") { |file| file << content }
      john
        sketchuh
        thanks, the red is changed.
        just want to confirm do i have to resize the window to square in order to have the thumb nail square?
          driven
          Currently, yes, and I don't know why the 'make square' button only works for some people...
          It may be because of Retina or system/SU language used...
          I have another way of doing it automatically, which 'batch mode' uses, but need some time to add it in and test...
          john
            driven
            Finally SketchUp has added it's own icons for mac with the release of v17...
            not the same quality [imho] but it's native and I can finally stop updating this plugin....
            john
            • G Offline
              greatoe
              john
              I've been using your plugin for years, thank you very much, John.
              It's good that SketchUp can make native icon for mac (again) now but I still prefer yours, which has larger resolution. And I think that 'file' frame in the icons SketchUp produce is useless and screen-landscape-consuming.
              • G Offline
                greatoe
                john
                Hi driven,
                This plug-in is not working on macOS 10.15 Catalina. Is there a chance that you would like to make a fix? 😄 😄
                  The latest MAC OS 'Catalina' does not support ANY current SketchUp version.
                  I know that SketchUp is working hard to release a new compatible update for version 2019 asap.
                  BUT no earlier versions will ever be made fully compatible.
                  Some might work, so will not - depending on how you use SketchUp etc.
                  So having an old Plugin updated seems to be the least of your worries !
                  Please complete your User-Profile so we know more details about your setup...
                  • 3 / 3
