    Vray 2.0 can't render more than 1200x800
    renderpluginsextensions
    5 Posts 4 Posters 919 Views 4 Watching
    • N Offline
      niuniuni
      Hi all,
      I try to render my SU scene which is 136mb big to resolution of 1920x900, but SU always crash after more or less an hour. I use default low quality exterior settings with output to vrimage. RT engine is GPU Cuda.
      I use SU 2015 64bit, Vray for SU 2.0. CPU i7, RAM 16Gb, GPU Nvidia Quadro K2000M.
      Is that not enough to render 1920x900?
      Have you got any idea what might be the reason to crash?
      • V Offline
        valerostudio
        How much memory installed on your machine. 64 bit is only as good as the amount of RAM you have. I have machines with 12 and 32GB and have never had an issue.
        Check your dynamic memory limit and set to 0.
        • dkendigD Offline
          dkendig
          he says he has 16gb of ram in his previous post. Make sure you have a 64bit OS installed, and you are running SketchUp 2015 x64, or you're wasting your time.
          Devin Kendig
          Developer
          • TedVitale_CGT Offline
            TedVitale_CG
            Are you trying to render using RT GPU?
            Ted Vitale
            Owner | Creative Director
            http://www.voxl.vision
            • N Offline
              niuniuni
              Hi again,
              Yes, I've got 64bit OS and SU, I use RT GPU CUDA for rendering. I've changed Dynamic Memory Limit to '0' and it helped a bit but I'm still not able to make more than 1920x1080px image.
              I've tried to render to VRimage and still the same problem. I turned of default displacement too. No idea what else can I fix.
              If you think there's any other solution, please help me.
