    Offset non coplanar curve
    16 Posts 8 Posters 3.0k Views 8 Watching
      cuttingedge
      hi guys I want to offset a non coplanar loop but I don't know which tool to use.
      If there was a face, I could use Tools on surface. But there is none.
      Thomthom's vertex tools could project faces along a direction but is it possible to say project outwards, from the center or say a distance from the edge. please see below.
      how to project selected non coplanar loop?
      • cottyC Offline
        cotty
        Not the direct way, but a kind of workaround:
        • select edges
        • extrude lines in blue direction (TIG extrude tools or Didiers Projections)
        • Scale with shift pressed
        • move up the scaled edges
        my SketchUp gallery
        • pbacotP Offline
          Have you tried Extrude tools-- extrude edges by vector to face? You are saying both offset and project, and I am not sure what result you are looking for, what direction and how far. Are you trying to add a skirt outward or down? Or is this picture the result?
          • cottyC Offline
            cotty
            • select edges
            Example:
            my SketchUp gallery
            • pbacotP Offline
              If Pilou is right, you could follow-me a shape and get rid of all but the required surface, Or there are many different ways. Scale a copy of the loop plus curviloft? (on test, this last would be my choice)
                You want this offset ?
                red one or blue one ?
                  cuttingedge
                  @cotty said:
                  • select edges
                  Example:
                  [attachment=0:1yudu5tp]<!-- ia0 -->offset_noncoplanar.jpg<!-- ia0 -->[/attachment:1yudu5tp]
                  yes this is the offset im talking about. your workarounds are all fine but i want to know whether is possible to project out a face with equal distance ( as in normal coplanar offset)
                  I tried doing the scale from center by pressing ctrl but this will not give me uniform offset distance
                  if my object is not circular as your example..
                  • BoxB Offline
                    You want to hit Ctrl and shift to scale uniformly about the center.
                      cuttingedge
                      @sdmitch said:
                      This code will create a horizontal offset curve.
                      Thanks Sdmitch this might just be what im looking for but i need faces generated upon offset. πŸ˜›
                      and to be honest, i dont know how to work with codes πŸ˜’
                      • BoxB Offline
                        Another version. Offset by Curviloft.
                        Copy, paste in place, scale, curviloft.
                        • sdmitchS Offline
                          sdmitch
                          This code will create a horizontal offset curve and faces.
                          mod = Sketchup.active_model
                          ent = mod.active_entities
                          sel = mod.selection
                          unless sel.empty?
                           crv = sel.first.curve
                           if crv
                            @osd ||= '1'.to_l
                            inp=UI.inputbox(["Offset;"],[@osd],"Horizontal curve offset")
                            if inp
                             @osd = inp[0]
                             edg=crv.edges;op=[];cp=[]
                             pv=edg[-1].line[1]
                             pvx=pv.axes[0]
                             for e in edg
                              p,v=e.line; vx,vy,vz=v.axes
                              ang=pvx.angle_between(vx);
                              vx.reverse! if ang > 90.degrees
                              bv = v + pv.reverse; bv.z=0
                              ang=v.angle_between(pv.reverse)/2
                              bv.length = -@osd/Math.sin(ang)
                              op<<p.offset(bv);cp<<p
                              edge=ent.add_line(p,op.last)
                              pvx=vx; pv=v
                             op<<op.first
                             ent.add_curve(op)
                             for i in 0...cp.length
                              e=ent.add_line(cp[i-1],op[i])
                              e.find_faces
                           else
                            UI.messagebox "Select Curve"
                          else
                          http://sdmitch.blogspot.com/
                            cuttingedge
                            Oh yeah why not, that's the way to go. Hehe, maybe I was just thinking this functionality
                            is available vertex tools... maybe in the next version πŸ˜„
                            Thanks Box for taking time to demo your tips box. How do you do this quick movies?
                            • BoxB Offline
                              I should put it in my signature I get asked so often.
                              It's a little screen grab program called gifcam.
                              • jeff hammondJ Offline
                                jeff hammond
                                what if the shape is something like this?
                                (just meaning to point out that scaling and offsetting aren't the same thing.. it only looks like the same thing on circles)
                                [add- and squares and equilateral triangles]
                                dotdotdot
                                  cuttingedge
                                  Good point Jeff, I know, everyone's suggestions are workaround as theres no available plugin I believe that does this directly. My issue with scaling is not having equal distance of projections. Another approach I thought is below using joint push pull.
                                    rv1974
                                    ancient 'extrudelinetool'+JPP is the way do do it effectively.
                                    @box: thanks for Gifcam.
