    Offset non coplanar curve
    16 Posts 8 Posters 3.4k Views 8 Watching
    • cottyC
      cotty
      @cotty said:
      Not the direct way, but a kind of workaround:
      • select edges
      • extrude lines in blue direction (TIG extrude tools or Didiers Projections)
      • Scale with shift pressed
      • move up the scaled edges
      Example:
      my SketchUp gallery
      • pbacotP
        If Pilou is right, you could follow-me a shape and get rid of all but the required surface, Or there are many different ways. Scale a copy of the loop plus curviloft? (on test, this last would be my choice)
          You want this offset ?
          red one or blue one ?
          • C
            cuttingedge
            @cotty said:
            • select edges
            Example:
            [attachment=0:1yudu5tp]<!-- ia0 -->offset_noncoplanar.jpg<!-- ia0 -->[/attachment:1yudu5tp]
            yes this is the offset im talking about. your workarounds are all fine but i want to know whether is possible to project out a face with equal distance ( as in normal coplanar offset)
            I tried doing the scale from center by pressing ctrl but this will not give me uniform offset distance
            if my object is not circular as your example..
            • BoxB
              You want to hit Ctrl and shift to scale uniformly about the center.
              • C
                cuttingedge
                @sdmitch said:
                This code will create a horizontal offset curve.
                Thanks Sdmitch this might just be what im looking for but i need faces generated upon offset. πŸ˜›
                and to be honest, i dont know how to work with codes πŸ˜’
                • BoxB
                  Another version. Offset by Curviloft.
                  Copy, paste in place, scale, curviloft.
                  • sdmitchS
                    sdmitch
                    @cuttingedge said:
                    hi guys I want to offset a non coplanar loop but I don't know which tool to use.
                    If there was a face, I could use Tools on surface. But there is none.
                    Thomthom's vertex tools could project faces along a direction but is it possible to say project outwards, from the center or say a distance from the edge. please see below.
                    This code will create a horizontal offset curve and faces.
                    mod = Sketchup.active_model
                    ent = mod.active_entities
                    sel = mod.selection
                    unless sel.empty?
                     crv = sel.first.curve
                     if crv
                      @osd ||= '1'.to_l
                      inp=UI.inputbox(["Offset;"],[@osd],"Horizontal curve offset")
                      if inp
                       @osd = inp[0]
                       edg=crv.edges;op=[];cp=[]
                       pv=edg[-1].line[1]
                       pvx=pv.axes[0]
                       for e in edg
                        p,v=e.line; vx,vy,vz=v.axes
                        ang=pvx.angle_between(vx);
                        vx.reverse! if ang > 90.degrees
                        bv = v + pv.reverse; bv.z=0
                        ang=v.angle_between(pv.reverse)/2
                        bv.length = -@osd/Math.sin(ang)
                        op<<p.offset(bv);cp<<p
                        edge=ent.add_line(p,op.last)
                        pvx=vx; pv=v
                       op<<op.first
                       ent.add_curve(op)
                       for i in 0...cp.length
                        e=ent.add_line(cp[i-1],op[i])
                        e.find_faces
                     else
                      UI.messagebox "Select Curve"
                    else
                    http://sdmitch.blogspot.com/
                    • C
                      cuttingedge
                      Oh yeah why not, that's the way to go. Hehe, maybe I was just thinking this functionality
                      is available vertex tools... maybe in the next version πŸ˜„
                      Thanks Box for taking time to demo your tips box. How do you do this quick movies?
                      • BoxB
                        I should put it in my signature I get asked so often.
                        It's a little screen grab program called gifcam.
                        • jeff hammondJ
                          what if the shape is something like this?
                          (just meaning to point out that scaling and offsetting aren't the same thing.. it only looks like the same thing on circles)
                          [add- and squares and equilateral triangles]
                          • C
                            cuttingedge
                            Good point Jeff, I know, everyone's suggestions are workaround as theres no available plugin I believe that does this directly. My issue with scaling is not having equal distance of projections. Another approach I thought is below using joint push pull.
                              rv1974
                              ancient 'extrudelinetool'+JPP is the way do do it effectively.
                              @box: thanks for Gifcam.
