    Workplane & Z Position Options?
    5 Posts 3 Posters 570 Views 3 Watching
    • P
      Penguin2
      I have a model where the ground floor of a house is 56.35 metres above sea level. I need to set my model correctly because the ground slopes above and below this level by as much as 7 metres above and below the finished ground floor level.
      I know I can reset the axis but is there anywhere where I can enter a Z co-ordinate of say 56.35 so that when I interrogate (another question below) my model I know exactly what level I am at?
      The other question: Is there anyway I can find the XYZ values of end points of edges.
      Believe me I have tried and I am sure I am missing some fundamental steps.
      Perhaps there is a tutorial somewhere that covers these basic issues.
      Thank you in advance.
      Regards,
      Andrew
        Did you try the label tool?
        • TIGT
          Coords-Tag from Datum
          http://sketchucation.com/pluginstore?pln=coordstexttagtoolfromdatum
          This should do what you want.
          Set the datum, leaving the model at z=0.
          Then any of its coord-tags you add will reflect the datum of z=0.
          Use options to format the coord-tags to show just Z if needed...
          • P
            Penguin2
            Thank you,
            TIG I will give this a go and get back.
            Regards,
            Andrew
            • P
              Penguin2
              Thank you TIG,
              Very useful. I think I can work with this.
              Regards,
              Andrew
