    Transparency glitch in vray material render!!
    renderpluginsextensions
    3 Posts 3 Posters 1.4k Views 3 Watching
    • S
      sudeep12
      i modeled a building in skp 2015 make.
      but my vray plugin is installed in skp 2013. so i saved the file in a lower version, rendered it in vray.
      problem- transparency control is not working.
      generally the skp control for transparency gets transferred to vray material. but in this case it isnt. is this a glitch?
      also when i try to edit material transparency in vray material editor, no result!
      please suggest!!
      • TedVitale_CGT
        TedVitale_CG
        Never make model changes in a newer version and then down save. That's a bad workflow and not supported. Download V-Ray for Sketchup 2015 and you wont have this problem. http://www.chaosgroup.com.
        Ted Vitale
        Owner | Creative Director
        http://www.voxl.vision
        • V
          valerostudio
          Also check to see Use Color Texture as Transparency is checked off for that material. If this is on, then it will not recognize the transparency from SU.
