    Wrong rotated textures
    7 Posts 4 Posters 499 Views 4 Watching
    • john2J Offline
      john2
      Often while modeling rectangular and straight faces when I apply texture, it gets applied in a rotated way? I have to manually then rotate the texture intuitively which is not accurate. How can I solve it? I have tried using thomthom UV toolkit but it does not solve this issue.
        How about an example image?
          driven
          are the faces reversed?
          john
          • Wo3DanW Offline
            Wo3Dan
            This happens with changed (rotated) drawing axes. Is this what happens in your case?
            @john2 said:
            I have to manually then rotate the texture intuitively which is not accurate. How can I solve it?....
            The green rotation pin snaps to edges and guides.
            A guide rotated a known angle makes exact rotation possible. Be sure to have the red texture pin on the edge/guide intersection prior to the rotation taking place.
            • john2J Offline
              john2
              Yes, that is exactly what was happening. Thanks for telling about the red pin πŸ˜„ πŸ‘
              I also found a plugin
              https://extensions.sketchup.com/en/content/eneroth-texture-positioning-tools πŸ˜„
                Still struggling with those screwed up axes from your poorly created CAD file, huh?
                • john2J Offline
                  john2
                  Yeah, I was running out of time. It was too late to make a fresh cad file with all the axes correct and then do Sketchupping again. That's why I was desperate for the plugin. But phew..I'm done with the work. I made a sketchup model for a 32 acre site which was the largest one I've ever worked upon. πŸ˜„
                  The funny part is that I never cared about axes in Autocad for 8 years or so (the same time I've been working with sketchup). And things went really well in sketchup.
                  But now in 2014-15 I faced this really big trouble. 😳
