    Ocean water rendering artifacts on single surface
    renderpluginsextensions
    4 Posts 2 Posters 801 Views 2 Watching
    • alemeratiA Offline
      alemerati
      I'm a beginner with rendering. I have spent a whole day trying to render ocean water with vray for sketchup (vray 2.0 version and sketch up pro 2014).
      I basically follow this good tutorial:
      https://www.youtube.com/watch?v=LAA2Yxe4P6E
      It looks ok for the most part, but I don't understand why I get part of the sea with different bumping and orientation.
      In the attached picture, you can see at least 3 different areas where this happens. But the water surface in sketch up is just 1 single rectangle. I really don't understand.
      Thanks for the help.
      Ale
      • TedVitale_CGT Offline
        TedVitale_CG
        This is because there is either a bump or a displacement on the surface. Try adding a map to the diffuse slot and disabling the mapping. V-Ray needs the diffuse mapping to generate UVW information that Sketchup doesn't provide at render time.
        Ted Vitale
        Owner | Creative Director
        http://www.voxl.vision
          alemerati
          So, is the video above incorrect?
          Anyway I will do some tests with a diffuse map, thanks for the advice πŸ˜‰ !
            TedVitale_CG
            The video is using V-Ray 1.49. 2.0 works a little differently and needs the Diffuse map to pull UVW information from the geometry.
            Ted Vitale
