    Problems with a half-torus
    156 Posts 11 Posters 26.7k Views 11 Watching
    • TeigT Offline
      Teig
      @d12dozr said:
      Great! It's a learning process, and you're getting a crash course πŸ˜„
      You're not wrong there!!! πŸ˜›
      Just trying to get a quote now, had one for Β£43 which I thought a bit harsh so I'm trying some other companies now.
      I can't see the plastic you recommended so I've just gone for 'standard' ABS.
      • TeigT Offline
        Teig
        Airbox Bellmouth2.skpI think I've cracked it!
        I've drawn another one tonight, a mere hour to draw:
        http://i1006.photobucket.com/albums/af190/Nursi555/A Mini/AirboxBellmouth2_zpsc2ec470a.jpg
        πŸ˜„
        • cottyC Offline
          cotty
          Looks good!
          You can use the soften edges window to smooth out some of the lines (no difference for printing, only looks nicer πŸ˜‰ ).
          my SketchUp gallery
            d12dozr
            That's about the best price for a part of this size on a commercial printer. Cost on a desktop printer is about 1/10 that price, which is the biggest advantage of using one of them. With your newer design, you actually have a little more room for cleaning out support material.
            @cotty said:
            Looks good!
            +1 πŸ‘
            On the flip side, this is closer to what it'll look like after printing:
            See the faceting on the curved bell surface? If you want that to print smooth, you'll need to increase the # of segments on the curves (Chapter 4 of the book). If the faceting is no problem, then you're good to go. πŸ˜„
            http://goo.gl/f7ooYh
            • TeigT Offline
              Teig
              The faceting is a problem, I would need to polish all those off to a mirror surface, for the bellmouth itself at least, the mounting flange etc doesn't matter.
              I've been told that some desktop printers will automatically build in support material so it looks like it's going back to that again πŸ˜„
              • TeigT Offline
                Teig
                Can I increase the number of circle segments now? Or will I need to redraw it from scratch again?
                  d12dozr
                  Definitely redo the model with higher resolution curves then - no reason to polish by hand more than necessary! Once you've push/pulled or follow-me'd, it has to be redrawn, unless you saved the intermediate steps like I show in the book.
                  Yep, pretty much any printer will automatically add the support material - that's whats shown in the T-rex model I posted before. Cleaning the support material is the tricky part, especially in an enclosed area like your model. Sorry if I didn't make that clear earlier.
                  Here's a video showing how the support material is cleaned out. On this particular model, it went very well.
                  • TeigT Offline
                    Teig
                    Thanks again d12dozr, that is a real help. I thought I had to put in all those supports and had been scrabbling around the t'interweb trying to find where and what spacing you put them in at. πŸ˜•
                    Back to the drawing board for v14 it is then.... πŸ˜„
                    • TeigT Offline
                      Teig
                      I am getting the hang of it! V19 was drawn in 45 minutes last night, solid first time πŸ˜„
                      Bellmouth50RRadialSlotSOLID.skp
                        Cool but you have forgotten the V6! πŸ’š
                        • TeigT Offline
                          Teig
                          You need to get up to speed Pilou πŸ˜„
                            d12dozr
                            New design is SEXY!
                            One question...is this area under much stress? If so it may be a good idea to add some meat so it doesn't break easily.
                            • TeigT Offline
                              Teig
                              Not much stress, it only has to hold the weight of itself up and the one my mate test-printed weighed in at 50g so not very much at all, nothing that a suitable washer won't support (I hope πŸ˜„). This version will weigh in a fair bit lighter too.
                              • TeigT Offline
                                Teig
                                Well since you pointed that out I've had the compulsion to fiddle πŸ˜„ But... I can't work out a way to add a bit of 'meat' to that area? Short of starting from scratch that is. To strengthen that area I've tried making an arc on the base and Push/Pulling but it leaves gaps.
                                v6 added for Pilou πŸ˜›
                                Bellmouth50RRadialSlot2v6.skp
                                  d12dozr
                                  I would try making the shape you want to add as a separate solid group, then use Outer Shell to combine them.
                                  • TeigT Offline
                                    Teig
                                    More study required...
                                    • TeigT Offline
                                      Teig
                                      I'm back again πŸ˜„
                                      I'm on version 34 (or so) now. After a lot of research reading mind-boggling papers on how to optimise the design I have changed my design slightly.
                                      I'm having problems with the Follow Me tool again, it won't do this:
                                      Is there any way I can make it work? I've tried it a few ways on different radius circles to follow, but it will not have it. I've tried it with half-circles and solid circles, this version is trying to be hollow to save weight. Anyone have any ideas?
                                      v6 for Pilou πŸ˜„: BellmouthRoundlip45Rv34.jpg
                                      BellmouthRoundlip45Rv34.skp
                                      • cottyC Offline
                                        cotty
                                        Moved the face away from the other geometry and scaled the model up (1000x)...
                                        my SketchUp gallery
                                          v6 for Pilou
                                          Not just for me but for all users who have not the same up version than you! πŸ˜‰
                                          PS you are making an engine in 3D Printing ?
                                          What will be the fuel ? And for what vehicle ?
                                          • TeigT Offline
                                            Teig
                                            [attachment=0:1vs06ddx]<!-- ia0 -->follow34.jpg<!-- ia0 -->[/attachment:1vs06ddx]
                                            That looks brilliant.
                                            Err.. How do I move a face away from the other geometry? Every time I try I get little 'strings' attached that just stretch out.
                                            And the scale tool. Sorry for sounding stupid but if I scale it by a 1000x what do I sale by to get back to my dimensions?
                                            Thanks.
                                            • 6
                                            • 7
                                            • 8
                                            • 4 / 8
