    ToolsOnSurface error
    12 Posts 6 Posters 662 Views 6 Watching
    • H Offline
      hanaehab
      So I'm using the joint push/pull button to make hole in my cylindrical room. It worked great for most of the openings but for some I get the attached error message. What to do?
      • massimoM Offline
        massimo Moderator
        Why the subject is "ToolsOnSurface error"? Souldn't it be "JointPushPull" error?
        • H Offline
          hanaehab
          @massimo why would you stop by to write that and not even answer the question? πŸ˜„
          • BoxB Offline
            For the same reason I will, if you want good answers, start with the right question.
            Fredo will have to answer this one when he gets to it.
            • H Offline
              hanaehab
              @box Okay, if there's an error with a specific function of a plugin, would you say the function has an error or the plugin itself? Of course the way I understand how plugins work may be wrong though
              Also, it seemed better to say ToolsOnSurface instead of JointPushPull in the title because I'm not sure how many people here are that familiar with specific functions in plugins. It just made more sense to use the plugin itself's name.
              And that's the long and short of it. Hope it satisfied you guys?
              • jeff hammondJ Offline
                jeff hammond
                tools on surface and joint push pull are two completely different plugins both with their own subset of functions..
                (tools on surface allows you to draw geometry on surfaces.. jpp allows you to push pull curved surfaces)
                just sayin.. (but really, i don't care about the misnaming or whatever)
                regardless, can you post the .skp or the portion of the .skp that you're having the problem with as well as explain the results you're after.
                dotdotdot
                • H Offline
                  hanaehab
                  ohhh wow okay now I understand why I got that question πŸ˜„ my bad box and massimo, I haven't been sleeping well for two weeks now 😳
                  @jeff hammond okay some of the opening are drawn on the cylinder, however when i try to push them into the cylinder (to later intersect faces and then make both sides of the opening windows) I get that error message.
                  error.skp
                    You've got a bunch of bad geometry on the bottom. Turn off the materials so they aren't masking the bad stuff. Clean it up and I bet it'll work better.
                    • H Offline
                      hanaehab
                      You're right @DaveR I checked out the bottom of that room and it was horrible. However on fixing it I still get the same error message 😞
                        jeff hammond
                        hey hanaehab.
                        you have some bad geometry in there.. lines that are really close together, stuff not in proper alignment, etc..
                        for example, this is zoomed way in on one part:
                        that little nick and things like it are going to potentially cause a lot of problems (and they're possibly what's causing jointpushpull to fail in this instance)..
                        in sketchup, along with most drawings/projects/etc, it often helps to think ahead instead of just getting in there and freestyling.
                        you want 10 windows going 360ΒΊ? then use a circle which is divisible by 10 (instead of the default of 24segments).. i used 60 in the .skp.. (doing this will allow you to draw one window and they'll all fit on the circle the same way) things like that.
                        here's your file with better starting geometry.. joint push pull should work on these surfaces.
                        error-jh.skp
                        turn on hidden geometry (View-> Hidden Geometry) and compare the two models..
                        (also, you have some hidden lines in your model.. basically, for now -- Don't ever hide lines.. only soften them (eraser tool + ctrl).. if they won't soften then you have another problem somewhere.. and hiding will only hide the error from being as visible.)
                        dotdotdot
                        • pbacotP Offline
                          IDK how disimilar your openings are but really could be simpler just layout the whole circle then create one opening and the section of wall each side and radial duplicate.
                          • H Offline
                            hanaehab
                            @jeff thank you sooo so much, do you know how to avoid having all that bad geometry for future reference?
                            @pbacot how would I go about doing that?
