    Windows 8.1 - SU2015 - small status bar text and tools
    9 Posts 6 Posters 890 Views 6 Watching
    • M
      mk11
      Just got a new laptop, win 8.1, installed SU and I have a few funky screen issues. I did search the forum but could not come up with any answers. The issue I'm having is the status bar and all tools show up super small, the tools are hard to use that small, and the measurements in the status bar are unreadable unless you use binoculars. Has anybody come across this and is there a solution to this?
      See screenshot. Laptop is an Asus UX301 with Intel Iris 5100, 2560x1440 resolution.
      Thx,
      Marc
      Marc Kleinmann
      SU Pro 2015
      Mac & Win
      • ntxdaveN
        ntxdave
        Try changing the set up for Windows by going to Personalization > Display > Medium resolution (125%).
        Makes everything a little larger but does not seem to affect the quality of things on the screen.
        Press F1...thank me later
        • M
          mk11
          I already have it cranked all the way to 200%. All windows look good, the SU main window looks good also, just the bottom status bar and tools.
          Marc Kleinmann
          SU Pro 2015
          Mac & Win
          • C
            CalypsoArt
            I was considering a Surface Pro 3, but they seem to have the problem of tiny icons and I haven't found any discussion of that being solved. I would want to run SU on the Surface If I got it.
            • K
              kaas
              @mk11 said:
              ... I have a few funky screen issues. .. with Intel Iris 5100, 2560x1440 resolution.
              Isn't this sort of the same problem as the people using a retina Mac are facing? The fact the new super duper high resolutions don't translate well into Sketchup's way of handling text / things?!
              • M
                mk11
                Actually not having any issues on my Macbook Pro, I have a Surface 3 and it's small but not as bad as on the ASUS. Does anyone know if there will be a fix for this soon?
                Marc Kleinmann
                SU Pro 2015
                Mac & Win
                • O
                  Openspaces
                  In Sketchup, have you tried going to Window-Preference-Workspace and Check the "use large tool buttons" box. Maybe it will help.....
                  • M
                    mk11
                    It's not about the toolbar. More the actual tool once it's selected ie tape measure, pen etc etc and the status bar at the bottom. Values are barely readable.
                    Marc Kleinmann
                    SU Pro 2015
                    Mac & Win
                    • P
                      pcmoor
                      Probably the best solution until Sketchup are able to update or give an alternative set of options; would be to plug in to a extra monitor. I find it quite convenient to run two and move my laptop between office and home
