    SU 2015 and styles problem
    7 Posts 5 Posters 4.9k Views 5 Watching
    • PixeroP
      Pixero
      I'm having problems with SU 2015 64bit and styles. What ever I choose shows as extremly bold halftransparent straight lines. I'm having this problem on both my PCs. Is anyone else experiencing this?
      I've checked the styles folder and all the styles seem to be there.
      Any ideas?
        Custom styles or default?
        • FrederikF
          Frederik
          This is definitely a bug and it has been reported to Trimble...
          I’ve found out that if you untick "Use maximum texture size" and then apply some of the Sketchy Edges styles, they will appear as expected...
          If you then turn the "Use maximum texture size" on again, the styles you’ve "loaded", will render correct and almost all other styles won’t appear correct...
          Cheers
          Kim Frederik
          • PixeroP
            Pixero
            Thanks for the info. Good to know I'm not alone. And thanks for the workaround tip.
            • K
              kaas
              Well, in the R15 maintenance releases it apparently hasn't been fixed because I just ran into the same problem (and solution).
              So, just a bump to get it noticed and hopefully fixed in the next release.
              • PixeroP
                Pixero
                Just tried and it wasn't fixed in SketchUp 2016 either. 😢
                • jenujacobJ
                  jenujacob
                  Even i was hoping it would be fixed... damn it!
                  Sent from my LG-D855 using Tapatalk
