    Render works fine, untill override material function is used
    renderpluginsextensions
    7 Posts 5 Posters 1.7k Views 5 Watching
      LARV
      When I try to render a scene with override material on nothing happens. When override is not selected everything is fine.
      Solution?
      ps. It has happened once before. Most of the time overide material works as it should.
        LARV
        Has no one of you heard of or encountered this problem?
        • dkendigD Offline
          dkendig
          If you ever encounter something that you believe is a bug, it's a good idea to include a copy of your error log(s) so we can see if something is breaking. There are 2 for our product (sorry), one is based on our Python code, the other is for Ruby stuff. To get the Python error log, you just need to go to Plugins->V-Ray->Debugging->Open Debug Window. This should open a dialog that displays the current python error log. For the ruby errors, it's best to open the ruby console (Window->Ruby Console) before the error occurs, to ensure that you catch all errors involved with the bug. So open a fresh instance of SketchUp, open the ruby console, then try to reproduce the bug. If you successfully reproduce the bug, check the ruby console to see if any errors popped up. Between the two logs, we should be able to better determine the cause of your issue. Without this information, we need to try to reproduce the issue ourselves, which can take time, and may not yield the same results as your machine.
          Devin Kendig
          Developer
          • TedVitale_CGT Offline
            TedVitale_CG
            Also, make sure you are running on the latest service release. We are currently on Service pack 3.
            Ted Vitale
            Owner | Creative Director
            http://www.voxl.vision
            • doppelD Offline
              doppel
              I already had this problem. Nothing happens when you click on Render with Override Material checked.
              It comes from some materials. When i delete these materials, the override material function works fine.
              • andybotA Offline
                andybot
                Did you check that your "problem" materials had the material override enabled? Were you using the current version?
                • doppelD Offline
                  doppel
                  Yes.
                  With vray 1.49, i never had problems with override materials.
                  This problem appears only with the vray 2.00.
                  I didn't download the Service Pack 3. I will do it. Hope that pack will fix this bug. Thanks for the info.
