    How do I make my lamp post cast lightrays in the dark?
    renderpluginsextensions
    6 Posts 4 Posters 823 Views 4 Watching
      LARV
      I have a lamp post with a spot light. The GI skylight is turned off, a spotlight is the only light in the scence. The spotlight lights up the ground, but I would also like to make the light cast some rays.
      Is there a simple way to make the spot light cast rays?
      Thanks!
        sketchuh
        maybe create a rectangle light (area light) then make it a component, rotate a 90 degrees. make it invisible. place it near the spot light. hope this helps.
          LARV
          OK, so I should try inserting a rectangle light in the lamp post and using that, removing the spot light? I´ll try it. Thanks!
          • jiminy-billy-bobJ Offline
            jiminy-billy-bob
            You mean that the light is ok, but you want to add these kind of effect?
            http://i.imgur.com/dwHJRqyl.jpg
            In Vray you can't (not yet). I would suggest to add it in post with photoshop.
            • dkendigD Offline
              dkendig
              environment fog is something that we plan on adding in an upcoming release.
              Devin Kendig
              Developer
                LARV
                Alright, thanks.
