    Volume with two different faces
    16 Posts 4 Posters 1.2k Views 4 Watching
    • Z Offline
      zorgloub
      Hello everyone,
      So, I started the grip of SU-8 and the basic issues are surfacing ... thank you already for your indulgeance so.
      Is it possible (and how?) To create a volume with two different faces.
      I think, for example, a round base cylinder and ending in a square.
      I do not see how to "link" the two different surfaces and create the volume between the two.
      File Schedule for practical exercise
      Thank you.
      Cheminée2.skp
        Like this? Fredo's Curviloft plugin can did this.
        • BoxB Offline
          Dave has given you an ideal plugin for this but it's also important that you understand the basic underlying geometry.
          http://i155.photobucket.com/albums/s296/storeben/SU/Geo.gif
          • Z Offline
            zorgloub
            Good Evening,
            Indeed, Dave, this is the result I am looking for ...
            I'll go see this plugin then!
            Thank you 😄)
            • Z Offline
              zorgloub
              Hello Box,
              Thanks Too 😄
              Your solution is analyzed too.
              But I do not get the command "Explode Curve" on top of the extrusion!??
              Regards
              Cheminée2b.skp
              • P Offline
                pcmoor
                As my teacher always said "if in doubt, right click", always look for a context menu
                • Z Offline
                  zorgloub
                  Hello,
                  I also tried using the "SandBox" function but the connection is not made on any base.
                  Any idea why?
                  Thank you.
                    The simple reason is the Sandbox wasn't intended to be used the way you are trying to use it. Just use Curviloft and get on with it.
                    • BoxB Offline
                      @zorgloub said:
                      Pity there have no Curviloft tutorial 😞
                      404 Not Found
                      (sketchucation.com)
                      • Z Offline
                        zorgloub
                        OK Dave,
                        Let's go for Curviloft soo...
                        I look to my friend google search (youtube, ...) 😉
                        • Z Offline
                          zorgloub
                          Again thank you all 😄)
                          Curviloft is top !
                          • Z Offline
                            zorgloub
                            Dave,
                            I venture to one final question:
                            How to delete all these construction lines (vertex?) To get only the built-up area?
                            As in your first example above.
                            This will serve me later to an unfolded form of this in a program such as Pepakura, for example.
                            Thank you.
                              In your model you have Hidden Geometry turned on. Turn it off under the View menu.
                              • Z Offline
                                zorgloub
                                Ah, ok
                                It's only a view configuration soo.
                                But is it possible to reduce the number of faces and vertex to simplify the model ?
                                  Yes. Reduce the number of segments in the shapes you drew for the top and bottom.
                                  This is fundamental SketchUp knowledge. You might want to spend some time learning SketchUp with simpler geometry so you can understand how to use it before you dive into the complex stuff.
                                  • Z Offline
                                    zorgloub
                                    Thanks DAve,
                                    Yes, certainly, I will with pleasure, but now I have a specific project and the handling of Sketchup is not easy 😉
                                    Still so many questions and so little time ...!
