    Volume with two different faces
    16 Posts 4 Posters 1.1k Views 4 Watching
      pcmoor
      As my teacher always said "if in doubt, right click", always look for a context menu
      • Z Offline
        zorgloub
        Hello,
        I also tried using the "SandBox" function but the connection is not made on any base.
        Any idea why?
        Thank you.
          The simple reason is the Sandbox wasn't intended to be used the way you are trying to use it. Just use Curviloft and get on with it.
          • BoxB Offline
            @zorgloub said:
            Pity there have no Curviloft tutorial 😞
            http://sketchucation.com/forums/viewtopic.php?p=248195#p248195
            • Z Offline
              zorgloub
              OK Dave,
              Let's go for Curviloft soo...
              I look to my friend google search (youtube, ...) 😉
              • Z Offline
                zorgloub
                Again thank you all 😄)
                Curviloft is top !
                • Z Offline
                  zorgloub
                  Dave,
                  I venture to one final question:
                  How to delete all these construction lines (vertex?) To get only the built-up area?
                  As in your first example above.
                  This will serve me later to an unfolded form of this in a program such as Pepakura, for example.
                  Thank you.
                    In your model you have Hidden Geometry turned on. Turn it off under the View menu.
                    • Z Offline
                      zorgloub
                      Ah, ok
                      It's only a view configuration soo.
                      But is it possible to reduce the number of faces and vertex to simplify the model ?
                        Yes. Reduce the number of segments in the shapes you drew for the top and bottom.
                        This is fundamental SketchUp knowledge. You might want to spend some time learning SketchUp with simpler geometry so you can understand how to use it before you dive into the complex stuff.
                        • Z Offline
                          zorgloub
                          Thanks DAve,
                          Yes, certainly, I will with pleasure, but now I have a specific project and the handling of Sketchup is not easy 😉
                          Still so many questions and so little time ...!
